Go Back   PowerArchiver Forums > Zip to Email (ZTE) > Tech Support
Closed Thread
Old 03-22-2012, 06:25 PM
moles42's Avatar
moles42 moles42 is offline
Alpha Tester
Failure to compress when using 'cloud' via outlook 2010
Zte still fails to compress the attachments when I opt to enable the attachment cloud service on the outlook toolbar.
if I disable it the files compress & send fine.
using the 'shell' options and the 'cloud' service appear to be functioning correctly.
it's only when using outlook 2010 that the problem arises.
tried reboot and clean installations but still the problem persists.
also confirming something 'Richard' touched on when replying to an email that previously had a zip attachment...if I try to reply and attach additional files to the email then Zte fails to compress them and sends the files in their original format.
Mike
Windows 7 Ultimate x64
Intel Core 2 Duo E6850 3.00Ghz
nVidia GEForce 8600 GT
4.0 Gig Ram
The Following User Says Thank You to moles42 For This Useful Post:
Mili (03-23-2012)
Old 03-23-2012, 11:02 AM
ivan's Avatar
ivan ivan is offline
Senior Members
I suppose you were using Outlook 2010 64-bit?
There was an error with OpenSSL on x64 and will be fixed in next release.
PowerArchiver Support
http://www.powerarchiver.com
The Following User Says Thank You to ivan For This Useful Post:
moles42 (03-23-2012)
Old 03-23-2012, 12:45 PM
are you sure additional files is not the filter? Does the compression options screen show up after you click send or?
Old 03-23-2012, 05:37 PM
moles42's Avatar
Alpha Tester
checked and rechecked filters spwolf...that's the first thing I modify after installation...
yes the compression screen does show up and I'm given the option to compress or not and then it goes through it's normal procedure.
yes Ivan I am using Outlook 2010 64-bit.
cloud service will only work through outlook 2010 x64 when I'm already logged into the account...
surely this isn't by design ?
this is probably an 'Opera' issue but when I try to download the file I've uploaded to attachmentcloud I only get the option to download a *.htm file instead of the zip file.
problem doesn't occur when using 'Chrome'
Mike
4.0 Gig Ram
Old 03-23-2012, 10:12 PM
Are you using this release?
http://dl.powerarchiver.com/zte10012.exe
Old 03-23-2012, 10:43 PM
moles42's Avatar
Alpha Tester
I am indeed
Mike
4.0 Gig Ram
Old 03-23-2012, 10:48 PM
so it still doesnt work in Outlook with AC?
Old 03-23-2012, 10:51 PM
moles42's Avatar
Alpha Tester
it will work but only if I've logged in manually at the site prior to me sending.
Mike
4.0 Gig Ram
Old 03-23-2012, 10:55 PM
it seems to work when you are doing new message and not work when you are replying...
... work meaning use of AC, otherwise it just compresses the file without usage of AC, right?
Old 03-24-2012, 05:37 AM
moles42's Avatar
Alpha Tester
if I haven't logged into my AC account then outlook fails to zip and send to AC even though it briefly flashes up a progress bar...this happens when it's a new message.
if I'm trying to reply to someone using Zte with attachment it also fails and just sends the files in their natural form and not zipped.
if I'm just sending files using Zte and not using AC then all seems fine unless I'm trying to reply to someone then it fails.
Mike
4.0 Gig Ram
  #11
Old 03-24-2012, 08:30 AM
TBGBe's Avatar
TBGBe TBGBe is offline
Still Mainly Lurking
Well, if you know enough to use Opera, then you probably already know that Opera uses the "type of document" information provided by the server (and NOT the filetype provided with document name). So more likely a server "problem"
Terry
WinXP SP3
The Following User Says Thank You to TBGBe For This Useful Post:
moles42 (03-24-2012)
  #12
Old 03-24-2012, 03:47 PM
they all do, right?
  #13
Old 03-25-2012, 06:16 AM
ivan's Avatar
Senior Members
Hehe, almost all browsers act in different way when it is file type, file name and other information send before download. We have fixed issues in IE 6,7,8,9, Firefox and Chrome, but there might be still some other browsers that detect based on different things.
Please specify Opera version so I will install and check with that specific version. Thanks.
  #14
Old 03-25-2012, 07:31 AM
moles42's Avatar
Alpha Tester
Opera v11.62 Build 1340...thanks Ivan.
Mike
4.0 Gig Ram
  #15
Old 03-25-2012, 10:13 AM
ivan's Avatar
Senior Members
The download issue has been fixed for Opera web browsers. Thanks!
moles42 (03-25-2012)
  #16
Old 03-25-2012, 10:44 AM
TBGBe's Avatar
they all do, right?
I did say "probably" and "likely"
Terry
WinXP SP3
  #17
Old 03-25-2012, 10:27 PM
moles42's Avatar
Alpha Tester
Thanks Ivan...are you referring to the 'next' release of Zte though?
Mike
4.0 Gig Ram
  #18
Old 03-26-2012, 12:16 AM
click on file inside email, and then link on the download page, that works for me... did your file possibly expire by any chance? (tested with latest Opera from their website)
  #19
Old 03-26-2012, 01:11 AM
moles42's Avatar
Alpha Tester
what's changed?....
just tested again and now appears to be working fine but I will do additional tests to make sure.
it's now uploading to AC without any issues but I've made no changes here...I'm testing in the same manner as I've done all week.
Mike
4.0 Gig Ram
  #20
Old 03-26-2012, 01:15 AM
thats server side, nothing to do with ZTE :-)
  #21
Old 03-26-2012, 01:19 AM
moles42's Avatar
Alpha Tester
nope failed again with second test...
as soon as I cleared cookies and logged out of AC and then tried to send to AC via outlook it failed once again.
I've got to be logged in to AC before outlook will successfully upload it.
Mike
4.0 Gig Ram
  #22
Old 03-26-2012, 01:27 AM
ivan was talking about Opera, not login... i dont know how login can work the way it works for you but i will check with ivan.
  #23
Old 03-26-2012, 01:38 AM
moles42's Avatar
Alpha Tester
clicking the download link in the email is now working fine in Opera...tested earlier and had no issues.
my only issue is still the AC one having to be logged in prior to uploading attachment.
thanks 'spwolf'
Mike
4.0 Gig Ram
spwolf (03-26-2012)
  #24
Old 03-27-2012, 02:02 PM
ivan's Avatar
Senior Members
moles, can you please try with version .13. thanks
  #25
Old 03-27-2012, 07:28 PM
moles42's Avatar
Alpha Tester
ok Ivan and I will report back later...many thanks.
Mike
4.0 Gig Ram
  #26
Old 03-28-2012, 07:12 AM
moles42's Avatar
Alpha Tester
Latest build seems to have fixed the issue I was having when using outlook 2010 x64 and 'AC'.
as far as replying to someone and then adding additional attachments to the email and using AC then everything once again appears to be operating perfectly.
forwarding an email also under the same conditions appears to be operating perfectly...I've not encountered any of the issues I had with earlier builds...
many thanks indeed guys...
Mike
4.0 Gig Ram
spwolf (03-28-2012)
  #27
Old 03-28-2012, 07:51 AM
ivan's Avatar
Senior Members
Thanks Mike,
If you find anything else, contact us.
Closed Thread
Cloud Client ampillion Wishlist 0 09-21-2011 07:31 PM
tar.gz failure mheyman Tech Support 2 07-28-2009 06:28 PM
Skin switch failure TBGBe Tech Support 4 07-07-2009 04:35 PM
Failure to create tar archive joakim_46 Tech Support 8 02-28-2009 09:50 AM
Zip failure Luxor Tech Support 7 03-27-2006 12:36 PM
