Closed Thread
Old 03-19-2012, 11:12 PM
jjsai jjsai is offline
Junior User
PA Crash as soon as the installation finish...
I have a MacBook Pro running Parallels v7 with a VM Microsoft XP Pro SP3. I installed PA 2011 and as soon as the installation ended and I click "Finish" with the "Run PA" option on I get the only windows error message asking if I want to send the report.
Does anyone have any idea why PA is not working on the VM? did I miss the prerequisite where it says "do not sun on a VM"?
Thanks,
Old 03-20-2012, 05:16 AM
Mili Mili is offline
Senior Members
And you were previously able to install PowerArchiver using previous versions? This started with 2011?
Has anything changed in the VM machine in between?
Old 03-20-2012, 09:17 AM
Originally Posted by jjsai View Post
Thanks,
from what you sent via support, it looks like you are using PA 2009, not PA 2011?
maybe some mixup with installations?
Old 03-20-2012, 09:32 AM
If you installed PA 2011 when PA 2009 was running, then it is possible that PA2009 .exe was left until restart, so now you have PA 2009 exe and rest of the files from PA 2011, which is why it would be crashing.
Old 03-20-2012, 11:26 AM
Junior User
Oops
Hi again and thank you for the fast reply.
The very first time I installed the PA was the newest downloaded directly from the website because I wanted to know if it works in the VM to pay for the upgrade. Since that did not work I try the version I have license for (2009) but none of them worked.
Right now I don't have any version install in my VM. Any suggestions?
Thanks,
Old 03-20-2012, 06:37 PM
there should be no problems with VM, we run PA in different virtual machines all the time, we do a lot of our testing like that.
can you clean up your installations, restart VM and install latest version from our website, then send us screenshot of the crash so we can see better whats going on.
Old 03-21-2012, 12:25 PM
Junior User
I follow your advice and remove the PA from the VM, then restart it and re install the new downloaded version of PA.
Here are the pictures:
The Following User Says Thank You to jjsai For This Useful Post:
spwolf (03-21-2012)
Old 03-21-2012, 10:17 PM
We have few people running the VM on OS X, and everyone is using vmware and not parallels... did you ever try vmware?
i remember that we tested in parallels few years ago when it came out, but that was probably different version then.
Old 03-21-2012, 10:23 PM
Junior User
No I haven't try vmware, I have a license for Parallels and I would like to keep it this way. If PA does not work with parallels that will be ok I just needed to know if it was worth it for me to upgrade to a new version. WCS I will be using some open source as I did when PA failed, not a big deal.
Thank you for your fast response and help.
Old 03-21-2012, 10:42 PM
i will try to see if someone has parallels check it out there, our 3 guys in the office used vmware for os x vm.
we dont have official os x testing computers... yet :-)
  #11
Old 03-21-2012, 10:47 PM
Junior User
Your efforts are appreciated I would prefer to have PA (because I like it) than 7zip or winzip. One thing I like about parallels is "Coherence" and that is a feature that I haven't see in VMWare.
Thanks,
  #12
Old 03-23-2012, 05:45 PM
Junior User
I found why it crashes: when I use the VM without the "coherence" feature the PA works!!!
It only crashes when in "coherence" mode!!!
spwolf (03-23-2012)
  #13
Old 03-23-2012, 10:13 PM
great!
Closed Thread
Tags
crash, parallels, virtual machine, windows xp
Notify when when all tasks finish in queue alextorex Wishlist 0 06-17-2010 02:08 PM
[PA 2009 final] crash on installation launcher Mad_Griffith Tech Support 2 09-29-2008 10:56 AM
