Rss Feed
Tweeter button
Facebook button
Outlook 2010 and plugin
Plugin doesn't even work in 2010... understandable as 2010 moved outlook to the ribbon. I assume this will be fixed, but I thought I'd give a heads up.
I found the plug-in does work, You need to use backstage (file) - Options - addin - then click add-in-options With PA Outlook installed it should bring up a dialogue box. See screenshots ![]() |
| The Following User Says Thank You to pjb For This Useful Post: | ||
spwolf (05-12-2010) | ||
Well i also found the plugin not working.. Hm
Will try it latter. |
I think the problem only occurs using the x64-Version of Microsoft Office 2010. I havent tried the x86-Version yet, but it looks like this would be the problem.
This problem also affected Apple using iTunes Plugin. The x86-Version ran fine, but the x64 wont. (for syncing data for example) I hope that ConeXware will compile the component for x64 so this nice component will be supported by Office. @ x86 Users It would be helpful if you could the test your Ofice-Plugin with your installation. I am using latest Outlook 2010 with latest (today downloaded) PA for Office withing x64 and it wont work. Thanks for you help! |
Unfortunatly there is one big problem with that - Delphi currently does not have 64bit compiler so it is impossible to just recompile our code.
Likely solution will have to be us moving to different codebase for PAOP in the future, that will support both.
ConeXware, Inc. latest PA release info on Facebook, Twitter | Follow us and win free PA 2010. |
good plans |
Previous Thread
Next Thread
| Outlook Plugin | tony_888 | Tech Support | 0 | 11-16-2009 09:19 AM |
| Outlook plugin take 100% cpu on startup | theweblord | Tech Support | 7 | 12-10-2007 11:43 AM |
| Outlook Plugin | cyberblob | Wishlist | 2 | 03-10-2006 10:28 PM |
| outlook plugin | davidsplash | Wishlist | 0 | 08-09-2004 09:39 AM |
Linear Mode
