Old 12-17-2009, 09:13 AM
spwolf spwolf is online now
New 7zip SFX for those who need it...
While we were finishing up 11.61 release, which was quite important, we got reported issue with our 7-zip SFX. It turns out it was quite (terrifying) slow when you have many files in it (reported issue was with 80,000 files). So as soon as 11.61 was out, we turned into fixing and improving that SFX.
New and updated version has instant startup, better progress and extraction times that are similar as in PowerArchiver. If you are using our 7zip sfx to distribute files to your users, it would be much advised if you get the updated version.
Here is the updated release: http://powerarchiver.com/test/PASZIPSFX-new.DAT
To install it, you need to download it, remove "-new" from the filename, and copy it to your PowerArchiver\Sfxs folder.
Thanks for being so great and happy holidays!
p.s. comments here:
http://www.powerarchiver.com/blog/20...e-who-need-it/
The Following 3 Users Say Thank You to spwolf For This Useful Post:
adsking (05-12-2010), Helena (07-01-2010), vancilrodo (11-02-2011)
7zip question moles42 Tech Support 5 09-13-2009 12:40 PM
Better 7zip support awo Wishlist 1 05-19-2007 04:45 AM
7Zip broken in 9.61.01 cavicster Tech Support 27 04-25-2006 07:35 AM
PPMD 7zip HandsomeGuy Tech Support 1 09-24-2005 07:47 AM
7zip davidsplash General 3 10-31-2004 08:26 AM
