Ideas: Full and far easier mutli-zip creation tool
Let's take an example : There are about 100 folders inside my main folder "A" : C:\A\1\first.txt C:\A\1\second.txt C:\A\2\first.txt C:\A\2\second.txt ... C:\A\100\first.txt C:\A\100\second.txt And there are also these files inside my "A"folder : C:\A\1.txt C:\A\2.txt C:\A\3.txt C:\A\try.zip If I use [CTRL+B] Within PowerArchiver, then it is very painful to use when there are many folders (100 in my case) to zip at once. Because I have to select manually "'add folder" for each folder!! ;-( In the above example I would like to have this result : C:\A\1.zip C:\A\2.zip ... C:\A\100.zip C:\A\1_1.zip C:\A\2_2.zip C:\A\3_3.zip C:\A\try.zip As you see there is also a problem when a folder and a file have the same name. I assume it would be great that automatically PowerArchiver add a "_" with a number so the files are not the same. Moreover if there is already a zip file in A (C:\A\try.zip), PowerArchiver will create another zip file (C:\A\try_zip.zip)! This is not needed IMHO. Many thanks in advance for implementing these ideas (which are really needed for me as I zip many files and many folders at the same time), All the best, Lip ps: I was using the freeware Rip-zip before as it was pretty powerful for such a task, but it creates bug on my computer (Xp) http://harmware.com/ripzip.htm. So maybe having a look at what it does would help you too? |
I think these were in the old wishlist forum but cannot be certain.
1. Quote:
2. Quote:
I'm not sure about the naming problem - as files are archived as "filename.ext.zip" and folders as "Dirname.zip" - but if the file has no extension, it may happen. 2a There was another wishlist to enable an option to exclude the extension when Batch Zipping files, just creating "filename.zip" - here the same name problem would exist). 3. Quote:
Also there were two others I do remember: 4. Rename Batch Zip Tool to Multiple Archive Tool {or similar} as all compression formats are possible. 5. Make Tool available from Explorer shell. Have I missed anything?
Terry WinXP SP3 |
Dear Terry,
Thank you for your answer. Please let me comment it hereafter : 1. "Quote: it is very painful to use when there are many folders (100 in my case) to zip at once. Because I have to select manually "'add folder" for each folder Using keyboard (e.g. Ctrl-A) to select ALL / using Mouse Shift-Click and Ctrl-Click to select Multiple - including both Files and Folders." I am sorry as I thought that my example was enough clear. But your answer is valid only if I want only a big zip file which would contain all that is stored inside the A folder ("C:\A\") of my example. In your example : you click on "new" choose a name for the archive and then click on "add files to the archive". This is not what I would like as I want to have all files and folders inside "A" zipped as a separate zip file. And I would like to make a very small number of click for that. 2. (...) "I'm not sure about the naming problem - as files are archived as "filename.ext.zip" and folders as "Dirname.zip" - but if the file has no extension, it may happen." I understand this. But let's take another example : I have one folder named "1" : C:\A\1\ inside this folder I have a file : C:\A\1\1.txt I have also another file in A : C:\A\1.txt So when I use the batch file [CTRL+B] I have the following results : C:\A\1\1_txt.zip and C:\A\1_txt.zip But this is not the result I want to! I would like to have : C:\A\1.zip and C:\A\1_txt.zip Please notice that I have more than 100 folders and also many files to zip at once. Try to do a CTRL+A (or SHift , CTRL) for selecting multiple folders and files and you will see that it does not work with CTRL+B (batch zip). ;-( 3. (...) "Automatic exclusion of existing archives (all formats) when Batch Zip is working with files - but not excluded if working with Folders (item 2 above). I am sorry but I don't understand the above statements. "4. Rename Batch Zip Tool to Multiple Archive Tool {or similar} as all compression formats are possible." Good idea! ;-) I have another idea : Add an option so we can choose to deleted the original files and folders once they are zipped. By luck did you give a try to Ripzip? IMHO, you should as you will see that zipping many files is very powerful and easy (beware of its xp bug)! Finally, I have another question : do you think that these easier features would be implemented any time soon? Thanks in advance, All the best, Lip |
Lip,
I am agreeing with you that it would be a nice option to have in the future. Quote:
But if a folder is selected, then the archive new folder archive should include all the files and archives in that folder. Quote:
![]() The only worthwhile feature seems to be the user interface for multiple file/folder selection as this thread is requesting. Quote:
Spwolf or Ivan may respond - normally they do look (and take note) of things in Wishlist, but do not publish acceptance of the idea/request for implementation. Except an occasional "hmmm .. good idea". Batch Zip Tool in explorer shell was originally a wishlist item from about 4 years ago
Terry WinXP SP3 |
Dear Terry,
Thank you for your answer. I appreciated. ;-) As PA customers I think we understand each other. ;-) Let's hope PA authors understand also and continue to update PA, so it will still be the best zip program around! ;-) BTW, you also right on ripzip (no need to install it, just have a look at these images : http://harmware.com/images/rzshot.jpg http://harmware.com/rztutorial.htm All the best, Lip |
any news on it
hmm, interesting idea ;-)
Thanks ;-)
any chance of this coming in 9.2? I have about 500+ folder in need of this operation.
