Old 03-09-2012, 10:27 AM
mdrd mdrd is offline
Junior User
Each file in separate zip file
I am using the Free vesion backup feature. Is it possible to put each file in a separate zip file?
Old 03-09-2012, 11:17 AM
TBGBe's Avatar
TBGBe TBGBe is offline
Still Mainly Lurking
PowerArchiver Backup doesn't support this, sorry.
However, you could produce individual archives using the Batch option/command (if available in free version) and then manually (or use Backup to schedule) to "store" the archives where you want.
Terry
WinXP SP3
The Following User Says Thank You to TBGBe For This Useful Post:
spwolf (03-09-2012)
[FIXED] Problem opening file inside a compressed file NCIBX Tech Support 6 12-12-2011 05:18 PM
"Put each file to separate archive" platanos General 4 04-06-2011 05:05 PM
[FIXED] Batch File to compress multiple file types DHaralson Tech Support 19 03-09-2010 09:05 AM
how to unzip file to desirable destination with batch file? BirgemBorg Tech Support 2 01-12-2009 11:15 AM
Successfully spanning a file in 1GB chunks (7GB total size of a single file) PoSeIdOnAs General 5 01-22-2006 12:56 PM
