Go Back   PowerArchiver Forums > PowerArchiver 2012 > General
Old 05-14-2005, 01:35 AM
wulffra wulffra is offline
PA Super User
Compress to filename/ (multiple archives into separate folders)
Using Windows Explorer, with the dir-tree in the left window, I'd like to select a few
directories in the right window panel and zip them using the directoryname as zip-file.
e.g. I have a number of directories in a 'temp-dir'.
In the explorer right window panel I select a few and RMB-zip them, incl. subdirs, etc.
In the ShellExtentions - there is an option to _extract_ to filename/ (multiple archives
into separate folders).
What about adding: Compress to filename/ (multiple archives into separate folders) ??
Thank you.
brgds
