Go Back   PowerArchiver Forums > Zip to Email (ZTE) > Tech Support
Old 04-25-2013, 05:11 AM
venkat venkat is offline
Junior User
Need command prompt code for zip file.
Hi All,
I am working windows machine.
I need code for ziping file using powerarchiver in command prompt. For unzip i will use the below code.
C:\Projects\Wrigley\POWERARC.EXE -e "C:\Documents and Settings\Administrator\Desktop\wa\ka6timwh.zip" "C:\Documents and Settings\Administrator\Desktop\wa\"
But i don't have zip code. can you please provide me.
venkat
Old 04-25-2013, 05:58 AM
Mili Mili is offline
Moderator
You should use the command line interface of PowerArchiver, called PACL.
You can find it at http://www.powerarchiver.com/download-powerarchiver/
It will include all directions on zipping and unzipping files via command prompt and using PowerArchiver's features.
command prompt problem kolbaszgyar Tech Support 5 09-28-2010 07:55 AM
command prompt issues (b3) Linkster Tech Support 11 07-18-2009 07:10 PM
I guess it's Command Prompt guido Tech Support 5 04-17-2009 08:12 AM
