Old 01-14-2013, 07:43 PM
AndyDBKiwi AndyDBKiwi is offline
Senior Members
Extract to shared folder triggers User Account Control dialog
If I copy a PowerArchiver 2012 to a shared network folder (e.g. \\LOCAL-WEB\Junk) and then extract it (to the same shared folder) I get a "User Account Control" dialog asking "Do you want this program to make changes to this computer?". Is this the expected behaviour?
Regards AndyDb
Old 01-15-2013, 06:54 AM
Mili Mili is offline
Moderator
Just to make sure, you have an archive on a shared folder and when you extract it to that same folder, you get the UAC dialog?
Are you extracting via right click options?
Old 01-15-2013, 03:04 PM
Regards AndyDb
what happens when you copy and past something there in the Explorer, do you get UAC as well?
Old 01-18-2013, 03:48 PM
CrimsonKnight13 CrimsonKnight13 is offline
Senior Members
I can confirm that this happens for me as well.
I have Windows 8 Enterprise x64 with PowerArchiver 2012 (newest build).
7zip extracts any archive to a mapped or direct-linked share w/o invoking UAC. PA2012, on the other hand, shows errors during the extraction process. I have attempted to extract files straight to a shared folder & drag-drop to the same folder. Both get the UAC prompt & then give an error that I don't have the correct permissions. I have verified that I have total access to these folders w/o any need for admin privileges or UAC-elevated admin access.
If you would like me to post screenshots, I can.
Old 01-18-2013, 04:26 PM
what format?
drag and drop copies files via Windows Copy function to those folders, are you sure that 7zip actually extracts those files properly there? Since with drag and drop, it is Windows doing copying and you should see Windows native dialogue, right?
Old 01-18-2013, 04:31 PM
Senior Members
Originally Posted by spwolf View Post
what format?
ZIP
7zip works with both methods. PA2012 gives an error when it attempts to temporarily extract to my user profile temp folder. I've tried the Local/Temp & LocalLow/Temp just to make sure it didn't have anything to do with UAC privilege level. The native Windows copy function & TeraCopy aren't invoked whatsoever since PA2012 errors out on all counts regardless unfortunately.
Old 01-18-2013, 04:33 PM
that means that PA cant extract to your temp folder? can it extract same file anywhere else, like on desktop?
btw are you using latest version of PA? 13.02? thanks :-)
Old 01-18-2013, 05:02 PM
in any case, it seems that in your case, it is problem with extracting that ZIP, no matter where, not a problem with extracting to network.
Old 01-18-2013, 05:53 PM
Senior Members
Yes, 13.02
Extracting temp files to current directory or Desktop doesn't work either. No temp folders as well.
I guess I'm SoL for now. :/
  #11
Old 01-18-2013, 05:56 PM
Yes, 13.02
how big is the file? I am assuming it is just that file that is creating problems? Other zips work fine?
  #12
Old 01-18-2013, 06:23 PM
Senior Members
I tried multiple ZIPs of 10 to 110MBs. No other files work fine with it.
  #13
Old 01-18-2013, 06:25 PM
so nothing works, cant extract any file with PA anywhere basically?
  #14
Old 01-18-2013, 06:42 PM
Senior Members
Well... I tried extracting to a shared folder that has the modify permission as Authenticated User in addition to System & Administrators. This time it worked.
Possible UAC issue on an admin account when extracting to folders that don't have a broader permission set?
  #15
Old 01-18-2013, 06:56 PM
i am getting confused, I thought it didnt work on desktop or temp?
  #16
Old 01-18-2013, 06:59 PM
Senior Members
It's because you are confused. :P
It only works on folders that have "Authenticated Users" or "Domain Users" with at least the modify or write permission. It doesn't work with folders that my own account or administrator accounts with full control permissions have access to.
  #17
Old 01-18-2013, 07:10 PM
maybe Antivirus? What AV do you have?
Otherwise did it work before and stopped working now or?
In general PA does not handle permissions at all, it uses Windows functions. Meaning something is not letting it work with files properly. Maybe you have set it to run under another user or something similar, some compatibility options?
If I understood correctly, it wont even extract files to your desktop? Thats not an option :-). Something is wrong.
  #18
Old 01-18-2013, 07:46 PM
Senior Members
I have Symantec Endpoint Protection 12.1.
Alright... I found out that a non-media related archive can extract to anywhere with PA2012.
The Desktop is a viable extraction point if media isn't in the archive. I'm quite unsure why this is occurring.
Permission errors w/ UAC still occur when SEP is disabled completely.
  #19
Old 01-18-2013, 07:53 PM
try uninstalling PA, restarting and installing again... if thats not it (some custom setting in Windows for pa.exe), then it is Antivirus blocking extraction and PA thinking it is due to permissions.
  #20
Old 01-18-2013, 09:17 PM
Senior Members
No good. Seems that it was working fine with my old account but since it became corrupted, I'm on a newly created account now.
  #21
Old 01-18-2013, 09:36 PM
when I changed accounts (well Win8 installation), it asked me if I want to make folders readable by changing permissions and voila, Win8 did it all for me... it might have been really fast due to the SSD.
  #22
Old 01-18-2013, 09:45 PM
btw, did you try using ICACLS for changing permissions via CL?
ICACLS "*.*" /grant "User":F
would make it change perssions to full for user named User.
icacls /?
gives help for changing permissions if thats the problem.
SPTD triggers Antimalware warnings Kai Fieabach Tech Support 4 09-14-2011 12:55 PM
Let User Add Subfolder to SFX Extract Folder i_am_jim Wishlist 14 08-17-2011 03:10 PM
Extract Here & Confirm Overwrite Dialog bgeneto Tech Support 2 03-28-2007 03:40 PM
How do I: extract to file name, multiple archives in a user defined directory wulffra General 13 03-13-2005 06:17 AM
Current Folder in Extract dialog lpatrick Wishlist 4 01-08-2005 05:27 AM
