Old 01-05-2013, 01:53 PM
Morph Morph is offline
Senior Members
"Hide filename" not available under encrypt 7zip format
In the past I used 7ZIP and was able to hide filenames during encryption of an archive. I bought PA (13.02.02 09/2012) believing that was also possible, reading the manual pages and online help. But when I select Encrypt, and then 7ZIP format, I cannot see "hide filename" as an option. It only exists if you choose PAE as an output format.
Bug? Its very helpful to hide the filenames as it clearly makes it harder to decrypt if you have no clue as to possible contents of each sub-file.
Mike
BTW - the captcha requirement on every post ... a bit excessive, and some of them are pretty hard to read as a human!
The Following User Says Thank You to Morph For This Useful Post:
spwolf (01-06-2013)
Old 01-05-2013, 05:19 PM
iDunk iDunk is offline
Junior User
Right click a file or files > "Compress To..." > "Compress With Options..." > Select format: "7-ZIP" > Encryption: "AES 256-bit" > check "Encrypt filenames".
The "Encrypt Files" dialogue in the main program window should probably be updated to include this option. I assume that is what you are using.
The Following 2 Users Say Thank You to iDunk For This Useful Post:
Morph (01-06-2013), spwolf (01-06-2013)
Old 01-06-2013, 10:53 AM
thank you, we will check it out...
Old 01-06-2013, 10:58 AM
Senior Members
Thank you - I can confirm this method works as you describe. And yes, I would certainly appreciate the option being included in the main program, which is what I tend to use.
Old 01-06-2013, 12:29 PM
Junior User
No problem. In case you want to compress and encrypt files or folders, there is the right-click method (also available from within PA main window), and there is the "New" > "New archive..." method, with a different dialogue, where "Encrypt filenames" is also available.
"Encrypt files" is mainly useful if you want to encrypt files which already are archives. However, it would be useful to have the option to encrypt filenames in this dialogue, too.
The Following User Says Thank You to iDunk For This Useful Post:
Morph (01-07-2013)
Old 01-07-2013, 03:35 AM
Mili Mili is offline
Moderator
Here is a test screenshot of 13.02.02 creating a new 7Z archive through main PA.
As you can see the "Encrypt Filenames" option is available and can be checked when encryption is selected.
I am assuming that you might have selected the Zip format which is why the "Encrypt Filenames" option is not available.
When entering the name of your archive, please select the 7Zip format in that same dialogue just below the file name field and everything should appear as in the screenshot.
The Following User Says Thank You to Mili For This Useful Post:
Morph (01-07-2013)
Old 01-07-2013, 06:54 AM
Senior Members
idunk - thanks again - your suggestion works.
Mili - your scenarios are correct, but here are two where "encrypt filenames" is not available, though it should be.
Create a new 7ZIP empty archive, without encryption.
Drag a file into the window, the attached popup appears. Select encrypt - filename option not available.
Create a 7ZIP unencrypted file with some content (a single file) or open an existing 7ZIP file.
Select Encrypt from Tools menu. Attached pops up - select 7ZIP, Encrypt AES - filename option again not available. This is the more common situation for me where I want to simply encrypt some archives and not others, that have been previously created.
Mili (01-08-2013)
Old 01-07-2013, 07:51 AM
Moderator
great finds Morph!
logging them in
Old 01-07-2013, 03:51 PM
Junior User
Wow, I've never even seen the Drag and Drop screen before. I guess we all have our own way of using our tools
The dialogue in the second screenshot was the one I assumed you were using.
Mili (01-08-2013)
Old 01-22-2013, 04:51 PM
Added Encrypt Filenames option to the latest update, Drag and Drop window... please update via patchbeam and let us know. Thanks!
[FIXED] 7zip - filename encrypt summermug Tech Support 38 06-26-2012 11:21 AM
Filename problem "3 0 0 .part001" guido Tech Support 21 03-18-2009 05:02 AM
PA2009b2: "Extract To Filename/" Bug H4ndy Tech Support 1 07-30-2008 04:42 AM
Batch ZIP creation: "Solid" 7zip option missing klumy Wishlist 2 08-19-2005 03:08 PM
