Rolling (limited) backup files - Howto ?
Is it possible to create a backup script that operates like rolling logs in Linux where up to some number of maxim files are created and then the oldest deleted the next time a backup is made?
All I can see is delete the last file option. Thanks, Christopher |
Sorry, but i dont think it is!
Might be worth emailing Conexware with a process you are trying to achieve and seeing if they can come up with a solution for you.
| Tags |
| backup limit rolling |
| Small GUI issue with PA2010 on limited user accounts | Big_Boss | Tech Support | 3 | 08-21-2009 02:01 PM |
| Corrupt backup archive. If VirtualStore\Program Files folder is selected. | Luxor | Tech Support | 28 | 03-14-2009 09:46 AM |
| backup: pick or exclude multiple target directories or files | port80 | Wishlist | 4 | 09-19-2008 03:22 AM |
| BackUp Scripts: Backup Registry Values | MarcFou | Wishlist | 1 | 07-22-2008 09:52 AM |
