Virtual Drive and Windows 8
I've just upgraded Windows 7 to Windows 8 and can no longer create Virtual Drives. I get an error "Check StarPort driver failed! Check if StarPort or StarPort Lite is installed".
I tried uninstalling and reinstalling PowerArchiver but it hasn't helped. Is Windows 8 supported? Steve |
oeemand and
I found the StarPort driver and uninstalled it, and then reinstalled PA and the driver, and all is good now.
Steve |
cool - in the future, just delete pavd*.exe in PA folder and check click on Virtual Drive inside PA, it will download and install latest release and problem solved... thank you!
| [FIXED] Virtual Drive PAVD2011 under Windows 7 64bit - Installed on incorrect drive | chierchio | Tech Support | 2 | 10-09-2011 01:12 PM |
| [FIXED] Virtual Drive PAVD under Windows 7 64bit | wulffra | Tech Support | 3 | 04-05-2010 09:48 AM |
| Virtual Drive not installing in Windows 7.... | Hercules | Tech Support | 3 | 07-09-2009 09:34 AM |
| Virtual Drive | itbytes | Tech Support | 2 | 07-26-2008 10:01 AM |
