Hi I have lastest version PA intalled Cab support after refresh it. The program won reload. Even On windows 7 64bit and new windows8 If you don't used version from 2007 then it would work. But I can't upgrade from 2007 on new windows 8. When I installed 2010 or newest one. PA 2012 doesn't work with cab support for windows setup. I get error on it. Please fix it asp thank you.
i have hard time understanding whats going on here :-)
As I was staying I can't get the PA Cab Setup support to work after you rezip it up as cab. When You click on Setup.exe That doesn't work I get error.
are you using correct CAB compression method? Maybe thats it?
Yes that correct no matter what I do. I need 2007 PA work on windows 8 to get PA 2012 work right way but Since that not that case. When I compress the cab support right way the click setup.exe let stay creative drivers on titanium driver set I make for mods tune up bass treble ect.. I get error after I updated the cab after compressing it.
Let me know of an example setup and what you do to it, so we can test internally here for one of the next releases...
Extract the cab support from creative then I rebuild the compress for creative cab and when I click setup.exe in main driver set I get error in the driver because I don't have 2007 installed but I have installed on windows 7 it works fine but not on 8. this my driver set you can test cab extracting and rebuild click on setup.exe in file
> http://dl.technewshw.com/driver/PAX/...k%20Edition.7z I got permission from creative long ago do driver mods right way .
| The Following User Says Thank You to robertmc8 For This Useful Post: | ||
spwolf (12-01-2012) | ||
Thanks When you extract and re compress the cab support the setup.exe wouldn't work with out 2007 PA. Please don't installed 2007 used the newest one. Then you can see that the setup.exe wouldn't work after you recompress the cab support on it. Using windows 8 pro 64bit. It works fine on windows 7 64 bit because I used 2007 PA to installed on top 2012 PA then it would prefect.
any news guys? I really like used PA 2012 with working cab support after you extract it then re compress it. It doesn't do that on windows 8 pro 64bit. When you click the setup.exe in set you get error setup code. If not I have used old xp and my usb flash drive do files that way from now on to you guys patch it.
#11
Bump any word please? It's not that hard. Just extract the cab from support then compress the cab support. Then You notice on the setup.exe doesn't work when you do on windows 8 pro 64 bit. Please fix don't make me call you. lol.
#12
hey robert, team is scheduled to work on new release soon enough... they will check this and let you know (when they start working on it)...
#13
Thanks for quick fix
There issue on my drivers on other side people in forums have where there setup issue staying upgrade to xp lol. I hope this is fix quickly.
#14
did you try copying cabinet.dll from PA 2007 to PA 2012? It should make it work actually, if the problem is with Microsoft's dll.
#15
Can you upload that dll to media fire for me? thanks.
#16
can you email support at conexware dot com and I will email it to you to check.. just reference this thread please... thank you!
#17
Here is the cabinet.dll from 2008... try this one (just replace it in your PA install folder).
and let me know if it works now.... thanks!
#18
Hi SPWolf Nope still same issue on windows 8 pro 64bit.
After extracting and recompress support cab main setup.exe doesn't work on windows 8.
#19
Bump any updates for this cab compress work on windows 8 pro 64 bit? thanks.
#20
Robert,
I tried opening Data1 cab with PA and 4-5 other tools, including Windows own, and it doesnt work. Is this what you are talking about?
#21
Ya Or support cab
. When you recompress it the main setup.exe won't open there be an error in it. If you have Titanium sound card from creative you can test the support cab with my drivers see what I was talking about. On windows 7 it works fine just having issue with windows 8 pro x64. Because 2007 doesn't installed on windows 8 pro. If you see the support cab in my driver folder you extract it and recompress it to updated the cab the setup won't launch after you do the re compressing it. That issue on windows 8 pro 64bit.
#23
Nope Issue still there cab support when you recompress it setup still won't work
#24
bump!
#25
Ya issue still there I post new driver link for you guys to test. http://www.mediafire.com/?2ifp9s95mkj1bx4 PAX MASTER PCIe Titanium Driver Suite 2013 V1.00 Default Tweak Edition Sorry about please retry thanks I updated the wdm inf
#26
it tells me invalid or deleted file?
#27
Test the support cab file for me when you click setup on it. You have creative titanium sound card? or any Creative cards let me know. I'll posted my driver mod set for you. I have dual boot to 7 now because of the cab compress issue on windows 8 pro 64bit.
#28
media fire link didnt work yesterday, but it works now so I will be checking it out... thanks!
#29
Here my new server link for the driver set > http://www.hardwareheaven.com/downlo...k%20Edition.7z
#30
Any updated news guys on Windows 8 pro 64bit? Where When you extract the Cab support and recompress it and click on setup.exe the setup get error when you launch it? I really want get this fix fast. I hate dual boot to 7 to make PA to work right way.
| PA 2010 11.50.57 GUI issues with Win7 RC1 | skypx | Tech Support | 13 | 07-07-2009 06:40 PM |
| Installing latest version PA Pro 11.3 | PA_Fan | Tech Support | 2 | 12-10-2008 12:00 AM |
| Can't Install Latest Version | Charles Botz | Tech Support | 1 | 10-03-2007 04:56 AM |
| Using latest version (rc2) unable to........ | skypx | Tech Support | 6 | 09-18-2007 03:53 PM |
