Old 10-28-2012, 04:51 AM
wulffra wulffra is offline
PA Super User
Drag&Drop: Zip file in same folder, with same name
When running PA and drag and drop a file into it, PA asks me for a filename and often stores it elsewhere, but not in the same folder of the original.
I mostly use the context menu.
But how do I get PA to
a) use the same filename
b) stores the zip file in the same folder
tks
Drag and drop bug drteeth Tech Support 2 09-02-2010 07:51 AM
Drag Drop file into archive deleted the archive!!! advo Tech Support 14 08-19-2009 04:46 AM
Serious 7-ZIP drag & drop bug in 9.61.03 Shivan Tech Support 1 04-25-2006 07:31 AM
Drag-N-Drop folder with relative path problem mwb1100 Tech Support 3 10-24-2005 03:47 AM
