Go Back   PowerArchiver Forums > PowerArchiver 2012 > Wishlist
Old 10-06-2012, 04:35 AM
dharmang1910 dharmang1910 is offline
Junior User
Please add support for PKZIP archives
hello PA Staff,
I'm user of PA Standard version & i'll very happy if power archiver can open & edit PKZip archives, because now a days many games archives are made with PKZip & have to install Pkzip for it...I uses power archiver since about 4-5 years so i don't like any other archiving utilities....so please try to add support for PkZIP...
Thank you....
Old 10-06-2012, 07:18 AM
i dont get it, we have support for pkzip archives, they are zip? You need to explain it better :-)
Old 10-06-2012, 08:14 AM
Sir Richard's Avatar
Alpha Tester III
Yes please because I've accessed pkzip archives in particular with non problems. Are you referring to features or as a gamer wanting to compress to pkzip.? Please explain.
Regards,
Sir Richard
Cheshire (UK)
NVIDIA Geforce GT 520MX
Old 10-06-2012, 10:15 AM
what is pkzip? I might not know :-)
Old 10-06-2012, 01:29 PM
Alpha Tester III
Check Wiki its all there my friend what I can tell you is pkzip who develops securezip application does an android version so painful needs to pick up the pace and do a PowerArchiver Mobile version. :-) ill even happily pay up to £10 for that app
Regards,
Sir Richard
Cheshire (UK)
Old 10-06-2012, 03:32 PM
i know who pkzip is, what I dont understand is that they create ZIP archives... so what exactly should we add?
Old 10-06-2012, 03:54 PM
Alpha Tester III
Sod if I know that's why we're waiting on dharmang lol
Regards,
Sir Richard
Cheshire (UK)
Old 10-07-2012, 01:10 AM
Junior User
ok,
let me explained something,
lots of game's archives which contains xml files and other data are made with pkzip and sometimes they have .pack extansion or no extension...but they all have common signature like
PK........YeI:................Awards/PK...........9...(............
all that archives are started with PK signature when open them in hex editor..
some of them are open and edit in Power Archiver but not all of them...this kind of problem i've faced in arc archives before...in which some of them can open in PA but not all of them......
so PKZIP and ZIP archives are different.....
Old 10-08-2012, 07:11 AM
you need to send us an example of such archives, PKZIP creates only zip archives, but maybe the method of compression is different.
most likely it is not pkzip creating these, and it has nothing to do with pkzip, as it is standard compliant.
in any case, send us one of files and we will know better whats goin on.
Old 10-09-2012, 10:50 AM
just to confirm, PK is marker for any zip file... it doesnt mean it was created with pkzip... PowerArchiver creates zip files that start with PK (and every other utility).
  #11
Old 10-09-2012, 10:47 PM
Junior User
Ok,
now i didn't remember which archive was not opened by PA so when i found it , i'll inform you...!!!
and thank you so much for the help...
Tags
pkzip
Support for PIM archives encode Wishlist 3 08-18-2006 06:34 AM
in regards to support for 7-zip archives. arbonarbot Tech Support 1 04-06-2006 02:59 PM
support for RK and PAQ archives. PAFuser Wishlist 4 08-19-2005 01:20 PM
PKZip compatible filename encryption mwb1100 Wishlist 1 05-20-2005 04:08 AM
PA 9.11.01 can't unzip pkzip files barryem Tech Support 6 02-18-2005 11:12 AM
