GUI: views in burner
When selecting the Burner Ribbon, you still have access to the interface and folders icon in the status bar.
When selecting one of these icons, the toolbars & panes are shown. I think these options should be disabled when selecting the burner ribbon.
Windows 7 x64 (NLD/ENG), I5-760 |
as it is
I think it is quite nice as it is. Although if other like Guido's suggestion, I wouldn't mind greatly if you changed it.
Could you explain why you like it the way it is? The menubar and folderlist that is shown, doesn't do anything? You cannot drag & drop or something?! And when you switch ribbons it gone again.
it allows you to switch from Easy and Advanced mode from the burner tab as well
Thinking about this while typing. I think it's pretty useless there (statusbar). If I do this in the ribbon, You do not switch between easy and advanced. You turn on/off Easy Interface.
| pa crashes when changing different windows/views | moles42 | Tech Support | 9 | 03-26-2009 10:21 PM |
| Views button is messing things up | guido | Tech Support | 6 | 04-20-2006 04:51 AM |
