Go Back   PowerArchiver Forums > PowerArchiver 2012 > Wishlist
Old 08-11-2012, 07:57 AM
wulffra wulffra is offline
PA Super User
Spanning, set sizes and encrypting to .exe
Feature request
a. Span and encrypt at the same time
b. Set max. file size per part
c. Encrypt to self extracting .exe
This all in the context menu.
Example:
I have a folder with a number of subfolders/files.
Total foldersize is 3GB
In in the context menu there would be a new item let's say:
"Span and encrypt"
1. I select the folder
2. Select the span and encrypt option
It would then present a pop up folder
asking:
2.a)either a max. file size, (e.g. 1700mb)
or
2.b) a number of parts (e.g. 3)
2.c.) password
It would then have to create either a
1700mb+1300mb file (.exe)
or
3 folders each 1GB.
I think, currently, this all is pretty difficult to achieve in 1 go.
The Following User Says Thank You to wulffra For This Useful Post:
spwolf (08-11-2012)
Tags
encryption, spanning
PAOP zipping files only between certain sizes ALoubert Tech Support 7 08-06-2009 04:07 AM
2009 B1: Column Sizes Not Saved MarcFou Tech Support 0 07-22-2008 08:54 PM
PA10 Bug: KB or MB sizes won't be shown within in archive masu Tech Support 6 03-09-2007 04:15 PM
Default column sizes By-Tor Tech Support 11 01-26-2007 11:01 AM
