Old 08-01-2012, 06:23 AM
JePe JePe is offline
Senior Members
Question Queue - Toolbox version required?
I am using the german version 13.00.26 of PA, so maybe I am using not the proper terms ...
In previous versions, the Queue could be en- or disabled with my version of PA; with the new version 2012 the "buy me"-window opens when I click on the menu within the options dialogue ...
.. is that intentionally the case or a bug?
Regards,
Old 08-01-2012, 07:18 AM
Mili Mili is offline
Moderator
Hello JePe,
Which menu exactly are you referring to?
Old 08-01-2012, 08:59 AM
Senior Members
This one ...
As you can see the menu item is not flagged with "Tbx", but when klicking it, a pop up appears begging for my money ...
Regards,
Old 08-01-2012, 09:43 AM
Moderator
Wow, this is a bug, logging it into our system for a fix!
Thanks!!
Old 08-01-2012, 05:26 PM
Thanks!!
does this happen only when user is registered but not tbx? in unregistered all is fine?
Old 08-03-2012, 05:29 AM
Moderator
Yes, when unregistered all is fine.
Happens only when registered with NON Tbx.
Adding info in to report
Old 08-03-2012, 02:48 PM
Originally Posted by JePe View Post
Regards,
hi,
you are able to turn on queue via compression window, right? or by running pastarter? Just to make sure you dont need a workaround until a fix comes.
Old 09-06-2012, 04:06 AM
this should be fixed in 13.01.03 release. Please update via Patchbeam and let us know.
PowerArchiver 2012 Toolbox Legacy vs PowerArchiver 2012 Toolbox Keith Weisshar General 4 05-24-2012 06:12 AM
Testing required: PAVD on 64bit Win7/Vista spwolf Tech Support 6 03-14-2010 04:23 PM
