Old 07-25-2012, 08:03 AM
Socrates Socrates is offline
Alpha tester
PAStarter
As I explained in an earlier note, I reinstalled PA (.26) using the download from the front page.
A new problem.
Whenever I close a PA window, it ALSO closes PAStarter -- which I don't want. That is usually the way I start PA.
Perhaps it was an unintended knock-on effect of some change in the installer.
Also another minor glitch. This occasionally happens before, but now . . . everytime.
I HAVE to have queue enabled for starter to work. Unless I do, when I close PA, it automatically closes starter -- every time.
Old 07-26-2012, 03:48 AM
Mili Mili is offline
Moderator
seems to work fine here.
Whether I close by going to File>Exit or clicking on X on upper right corner, PA starter stay available.
Anyone else?
Old 07-26-2012, 07:03 AM
Alpha tester
did you
Did you try it with Queue not enabled?
Old 07-26-2012, 07:14 AM
Moderator
Yes, have tried both instances and starter stays available after exiting PA in both.
Old 07-26-2012, 07:24 AM
Alpha tester
odd
Odd. Well, it is likely a peculiarity of my system. Thanks for checking.
Closed Thread
PAStarter.exe crash. talonius Tech Support 6 12-11-2009 09:57 AM
PAstarter problems plattejo Tech Support 11 09-18-2009 03:30 PM
