Old 07-24-2012, 07:26 PM
Socrates Socrates is offline
Alpha tester
another pbs problem
For several days, when I try to run a pbs, I won't upload my file.
And even by FTP window looks odd. There are no profile options in the drop down window, no username.
I had uninstalled ZTE (which was registers to my version 12 license) and reinstalled PAOP.
Could that be the culprit?
If so, any idea why?
BTW, you going to put .26 up on patchbeam? Wasn't sure if that might fix it.
Old 07-25-2012, 07:17 AM
Alpha tester
close
you can close this.
I reinstalled the latest version from online (wish it had been available via PB).
The FTP options are now present and in working order.
Sorry. Probably should have just tried that first . . . but I feared I might make matters worse.
The Following User Says Thank You to Socrates For This Useful Post:
Mili (07-26-2012)
Closed Thread
