Old 07-14-2012, 02:21 PM
tip2tail tip2tail is offline
Junior User
Talking Create a Reg Key file
I am a PowerArchiver license key owner. I am trying to create a silent install application that will install all my main applications straight after I reinstall my operating system.
I can install PowerArchiver silently no problems but I would now like to integrate the registration information after I have installed. Either by Registry entry file or Batch file or any other method.
Can anyone assist me?
Thanks,
tip2tail
Old 07-14-2012, 09:01 PM
yes, please email us at support at conexware dot com and we will send you PDF with advanced installation instructions... thanks.
Old 07-14-2012, 09:04 PM
actually if you just need to save your settings, which includes reg info, go to Config button, click on down arrow and you will get export option for the settings :-). It will export the .reg key which I am sure you know you can merge silently via regedit /s.
Old 09-06-2012, 04:08 AM
You can also find advanced installation instructions here:
http://wiki.powerarchiver.com/en:hel...n_instructions
Might be overkill for you but it might help someone else... thanks!
How to create individual zip file for each of the file/folder in a folder? lit2fly Tech Support 5 09-07-2010 03:35 AM
Create an encrypted file MuMo1234567 Tech Support 5 07-09-2007 08:15 AM
Create Exe File from ZIP vman General 3 07-26-2006 04:07 AM
