Old 07-06-2012, 07:57 AM
Jeremiad Jeremiad is offline
Junior User
File listing problem with bigger files
Seems that there's problems listing "detailed" information from bigger Zip files. In this case i have 47Gb zip file.
Zip's structure is: Main folder -> 2 sub-folders and so on.
And when its trying to get detailed information from this main folder it fails. Window stays blank. Doesn't even show the main folder. If i switch to list view, thumbnails or something else it works just fine.
And also is there a way to change language to English in international version?
PA version is: 13.00.24
Old 07-06-2012, 09:14 AM
Luxor's Avatar
Luxor Luxor is offline
Alpha Tester
Welcome Jeremiad
I'll let support answer your first question.
As for your question regarding changing languages, if you are using the modern interface you should have the option "Change language" in the Options toolbar as shown in my screenshot. If you are using the classic interface it is under Options > Change Language.
Vista home premium SP2. Always the latest Powerarchiver Toolbox
Old 07-06-2012, 09:21 AM
Junior User
Hehe, I must be blind for not spotting that. Thank you!
Old 07-06-2012, 10:54 AM
Originally Posted by Jeremiad View Post
how many files inside?
Old 07-06-2012, 11:14 AM
Junior User
Odd, now it seems to be working when language is English. This problems was when PA was in Finnish.
Theres 24 files and 12 dirs.
So problem is that its missing translations?
Old 07-06-2012, 04:31 PM
try again in finnish and what happens? If it still doesnt work, save your settings via Config button> Export settings and send them to support at conexware dot com.
I have tried Finnish and all seemed fine but i probably dont use same options as you.
Old 07-07-2012, 04:56 AM
well, i see now that something similar was fixed in upcoming release - "file contents not seen when changing languages, only with some languages"... does that sound familiar?
Old 07-11-2012, 01:24 AM
davidsplash davidsplash is offline
PA Super User
is there a limit on the size of zip file as every archiver has a limit.
Old 07-11-2012, 04:32 AM
there is no practical limit, it is in petabytes or something like that... i think problem was with translation, nothing else.
Old 07-12-2012, 09:13 PM
please check PA 2012 13.00.25 via Patchbeam and see if it works better now... thanks!
Sending file listing to clipboard Claude Renaud Wishlist 0 01-20-2009 12:46 PM
Print file listing -> to clipboard klumy Wishlist 10 09-09-2006 11:01 AM
PA 2007 : Print file listing to clipboard Claude Renaud Wishlist 0 05-24-2006 04:15 AM
A new print file listing option Claude Renaud Wishlist 1 08-15-2005 11:59 AM
