Old 06-26-2012, 07:16 PM
Socrates Socrates is offline
Alpha tester
Exclamation FTP -- sorry not closed
I spoke prematurely.
The FTP works with FTP + SSL.
But there is a huge problem.
Once I use it in a pbs job, it resets the profile to SFTP -- which does NOT work.
As long as I don't try to use a pbs, all is fine. But once I do, it's all over.
You might want to fix this before the new patchbeam.
ADDITION: I thought maybe complete redoing the pbs files from scatch would help. Nope. FTP + SSL will not stick in a pbs file. It defaults to SFTP which does not work.
The Following User Says Thank You to Socrates For This Useful Post:
spwolf (06-26-2012)
Old 06-27-2012, 08:03 AM
Mili Mili is offline
Moderator
Reproduced this, logging it in. Thanks!
Old 06-27-2012, 08:17 AM
Alpha tester
Thanks.
Old 07-12-2012, 08:05 PM
Alpha tester
not sure
I tried running a PBS with encryption.
The progress bar went to 100%, but never said it was done -- not even after 2 minutes after it reach the end of the bar.
What would cause this?
Ideas?
Old 07-12-2012, 08:46 PM
send the pbs to support and they will try to reproduce the issue, i have no idea... btw - does the new version work fine with FTP in backup?
Old 07-13-2012, 05:01 AM
Alpha tester
answer
After waiting for 2 minutes I finally stopped it — and it had worked (although the update is much slower (by at least a factor of 2) than the same transfer with FileZilla using the same encryption.
So I will try it a couple more times and if isn't fixed, I can just use FZ.
Having the FTP is nice, but its not the main thing I like about PA. Your program already does so much. I cannot expect it to do everything well.
Thanks for trying.
Old 07-13-2012, 05:07 AM
oh you meant the sftp transfer was slow? i didnt quite understand... it should be exactly the same speed, maybe there was something else going on? ssl overhead is pretty small.
Old 07-13-2012, 05:42 AM
Alpha tester
also
I realize I was unclear. It created the archive just fine.
And it uploaded the file (albeit, very slowly). But THAT is where the progress bar showed that the upload was 100% complete, but I never saw the "it's finished" (sorry, don't remember the wording) dialogue box. Finally I manually stopped it (2+ minutes later). Although there was the no notice that the PBS has finished uploading, the upload was successful.
Old 07-13-2012, 09:45 AM
Alpha tester
OK now
After two reboots, everything went smoothly.
spwolf (07-13-2012)
Old 07-13-2012, 09:56 AM
we have tested it ourselves in the meantime, same speed between the two... it was probably something specific with connection at that particular time.
Closed Thread
