Thread Tools | Rate Thread | Display Modes |
English version auto-updating to International version
Hey Guys,
Just wondering if anyone else has this problem, and more importantly a fix. So I register the English version, and all is fine. Then Patchbeam will run, and auto install the International version (no way to tell which version is being installed until AFTER the installation). Of course I go to enter my rego info, and bam. No go. So I have to un-install, restart, re-install. And its a major pain in the ass. It has happened a couple of time now.. hence this post. I need a fix. Any ideas would be most welcome. Thanks! Draxxx |
Hi - new PA 2012 has same installer for both versions, so it will be easier for users to download what they actually want to use, without too much thinking.
You can use both codes - if you use English, it will simply enable English language only. Your problem is most likely that you need latest codes for version PA 2012, which you can get from your account: https://www.conexware.com/shop/ Also - there is no auto install. You have to press Update and then click through complete installer for it to actually install. We did this on purpose for major versions as supposed to quick Patchbeam update which would usually be 2-3 seconds.
| The Following User Says Thank You to spwolf For This Useful Post: | ||
Draxxx (06-23-2012) | ||
Thanks spwolf!
Your hunch was right, I need to update my keys. And you're also correct regarding the update procedure. ![]() My bad for not describing that correctly. Thanks for your help! ![]() Dx |
| The Following User Says Thank You to Draxxx For This Useful Post: | ||
spwolf (06-23-2012) | ||
thanks, i am glad you were able to find quickly what you need... have a nice weekend and enjoy PA 2012!
| Tags |
| english, international, patchbeam, update |
| new version | davidsplash | General | 3 | 09-18-2010 05:48 PM |
| when will next version be out | davidsplash | General | 2 | 06-25-2008 05:25 AM |
| which version of PA out now? | Naruto | Tech Support | 4 | 05-24-2007 05:42 PM |
| 7-zip version? | Cyber Dog | General | 3 | 04-28-2006 08:33 PM |
| Mac OSX Version? | saint | Wishlist | 4 | 11-03-2005 03:11 AM |
