Old 06-18-2012, 09:02 PM
Socrates Socrates is offline
Alpha tester
pbs and RAR
I have not yet purchased WinRar. But if I do, can I use winRar to compress and files run by pbs files?
The option does not appear to be there now . . . but may it appears once I have purchased and installed WinRAR.
Old 06-19-2012, 02:57 AM
Sir Richard's Avatar
Alpha Tester III
Hi Socrates,
1st, Download a trial of WinRar then go into PowerArchiver Configuration and add the location of the "rar.exe" container via RAR Support tab and Click OK.
Then Go back into config select "Shell Extensions" you will notice on the right site panel Compress to RAR is available to add to your PowerArchiver menus.
The point of the rar support is so you can Compress RAR formats without the need to switch over and use WinRAR.
PA just utilises the container file so it can compress rar formats as you know PA already can extract and open rar formats faster than winrar itself.
By installing winrar as a trial and setting up PA you can play around with both applications to see if it suites your needs before spending your hard earned cash.
Regards,
Sir Richard
Cheshire (UK)
NVIDIA Geforce GT 520MX
The Following User Says Thank You to Sir Richard For This Useful Post:
Mili (06-19-2012)
Old 06-19-2012, 04:18 AM
Mili Mili is offline
Moderator
We do not have RAR as an option in PBS scripts as we would not be able to have about 50% of the backup functionality with it as with other formats, filters, etc.
So for now, it's left out.
Old 06-19-2012, 05:01 AM
Alpha tester
Understood. Makes sense.
Thanks.
The Following User Says Thank You to Socrates For This Useful Post:
Mili (06-19-2012)
