Old 06-06-2012, 07:16 PM
BookWyrm BookWyrm is offline
Senior Members
Issue with virtual drive
I'm running the PA 2012 beta with the virtual drive.
I can mount and access the ISO files without issue, but there is an issue when I go to unmount or remove the virtual drive.
The initial attempt says everything succeeded, but then I get a message from Windows that it was unable to remove the device and the drive remains mounted.
Running Windows 7 SP1 x64.
Old 06-07-2012, 04:54 AM
Sir Richard's Avatar
Alpha Tester III
Bookwyrm,
Thank you, for your post.
Can you verify that you have downloaded Beta 2 (12.00.18)
I can clarify that this is a known issue the alpha team and developers have been discusing.
You should be able to Unmount the drive by right clicking on PAStarter and Selecting "Unmount & Remove Device..."
Try and ensure the "My Computer" Window is closed to ensure this unmounts the device.
It seems that when the user is in "My Computer" it goes through the process of unmounting but something is locking PoweArchiver's Driver from doing it. But when the user removes the drive using other dismount options in PA's program it works.
My view on this is the 1st port of call for a user would be to right click on a device and dismount it. Although, there are other ways this shouldnt mean we should give up and find a fix.
Regards,
Sir Richard
Cheshire (UK)
NVIDIA Geforce GT 520MX
Old 06-07-2012, 05:07 AM
did you by any chance download and install beta 1 first?
Old 06-07-2012, 07:38 AM
Socrates Socrates is offline
Alpha tester
unmount
I have always occasionally had this problem too with successive versions of PA. But if I did, I just went to the "Safely Remove Hardware" icon in the system try, clicked on the VD I wanted to remove, and that solved the problem. Always seemed, at most, like a minor glitch, one with an easy workaround. Besides, I assumed (perhaps wrongly) that it was just something else going on somewhere in my system.
The Following User Says Thank You to Socrates For This Useful Post:
spwolf (06-07-2012)
Old 06-07-2012, 08:35 AM
there was an bug in b1 that made it impossible to unmount VD, it was fixed in b2 however it involves that user uninstalls the driver and reboots before installing new one. Which is why i asked if he used b1.
Old 06-07-2012, 11:25 AM
Senior Members
I did indeed use B1 and upgrade to B2. I'll do the uninstall of the virtual drive and reboot/reinstall and see what I get.
The Following User Says Thank You to BookWyrm For This Useful Post:
spwolf (06-07-2012)
Old 06-08-2012, 09:01 AM
Senior Members
Unfortunately the uninstall/reboot/reinstall did not seem to resolve the issue.
Old 06-08-2012, 09:10 AM
did you uninstall PowerArchiver Startport drivers, reboot and then downloaded and installed latest drivers? It has to work :-)
Old 06-08-2012, 09:17 AM
Senior Members
I did the uninstall via Programs & Features control panel and rebooted.
The install of the latest drivers, I just opened PowerArchiver and selected Virtual Drive and let it install them. According to PatchBeam the virtual drive is version 1.05.02
Old 06-08-2012, 09:18 AM
but you uninstalled the drivers right? Since uninstalling PA wont do anything.
Patchbeam just shows virtual drive version, not actual driver version.
  #11
Old 06-08-2012, 09:24 AM
Senior Members
The app I uninstalled via Control Panel was "StarPort Drivers for PowerArchiver Virtual Drive Emulator", I assume that's the right one?
The controller I see in Device Manager is 'StarPort Storage Controller (Lite)'. The drive is StarPortLite.sys with version 3.5 Build 20080111
  #12
Old 06-08-2012, 08:41 PM
that should work... how are you unmounting? Did you try via shell or any other way?
  #13
Old 06-08-2012, 09:06 PM
Senior Members
I did the unmount via the PowerArchiver gui; selected the Virtual Drive from the ribbon and selected unmount.
Is there a different way to try?
  #14
Old 06-09-2012, 03:30 PM
Mili Mili is offline
Moderator
lets try this,
Uninstall Starport drivers
reboot computer
download and install this driver;
http://dl.patchbeam.com/conexware/pa...rt15002int.exe
  #15
Old 07-20-2012, 08:46 AM
vinko vinko is offline
Junior User
why I can not install any games with PA 2012 Toolbox?Is there any solution for this?
  #16
Old 07-20-2012, 09:36 AM
Moderator
Vinko,
What sorts of issues are you having which make it seems like there is something wrong with PA VD?
Personally, I've installed some programs/games using PowerArchiver's VD and it worked fine. Of course, that does not mean it has to work fine for you.
Please let us know some details and we'll do our best to help.
  #17
Old 07-20-2012, 11:30 AM
Junior User
I want to install the game. I choose .iso image, right click, mount VD and then wait VD and nothing happens....
  #18
Old 07-20-2012, 12:11 PM
Moderator
Vinko,
Please try the following;
Open PowerArchiver
Go to the Burner menu
Click on the Virtual Drive button
You should be asked whether to install drivers, click Yes.
Once they are installed, go back to the same Virtual Drive button and click it, you should get PA 2012 VD working then and the right click option should also work as well.
Let me know if that worked.
  #19
Old 07-20-2012, 01:18 PM
Junior User
no luck .... now I have a computer crashes every time when PA VD wants to install software..
how sorry I am that I bought a license for PA 2012 Toolbox
  #20
Old 07-20-2012, 03:48 PM
Junior User
I also tried with daemon tools and Alcohol 120% and even with these softwares I could not install the game and office... what could be the cause of my problem?
  #21
Old 07-21-2012, 06:19 AM
Alpha tester
thought
Are you running PA with administrator privileges? If not, the installation may not work.
Or perhaps you are not running the setup on your VD with administrator privileges.
Since this is not a problem I have ever heard mention, I am betting that it is a problem with a setting like those mentioned above, or some other clash on your system.
  #22
Old 07-21-2012, 12:52 PM
Moderator
Hi Vinko,
Were you able to install the VD drivers properly?
If not, here is the direct link to them;
http://dl.patchbeam.com/conexware/pa...rt15003int.exe
If you have, then what errors are you getting when trying to use the VD.
Also, please do try running PA as admin as noted by Socrates and see if that helps.
  #23
Old 07-22-2012, 04:25 AM
Junior User
re-install Windows 7 was the only solution .... PA 2012 Toolbox is now working very well....
  #24
Old 07-22-2012, 06:41 AM
Alpha tester
glad
Glad it was fixed. But what a time-consuming solution. Sorry.
  #25
Old 07-23-2012, 03:55 AM
Moderator
Glad it works Vinko!!
  #26
Old 07-23-2012, 04:50 AM
moles42's Avatar
moles42 moles42 is offline
Alpha Tester
I'd be lost without my virtual drive...
Mike
Windows 7 Ultimate x64
Intel Core 2 Duo E6850 3.00Ghz
nVidia GEForce 8600 GT
4.0 Gig Ram
  #27
Old 07-23-2012, 05:20 AM
who knows, probably some driver messed up all the virtual drives as you tried them all.... I will be closing this thread so if something else comes up, open new one... thanks.
Closed Thread
[FIXED] Virtual Drive PAVD2011 under Windows 7 64bit - Installed on incorrect drive chierchio Tech Support 2 10-09-2011 01:12 PM
New virtual drive issue in 2011 RC2 crohan Tech Support 7 03-22-2011 12:08 AM
