Volume Shadow Copy on WinXP
We use PowerArchiver 2011. On Windows7 we can backup
open Files with Volume Shadow Copy. But this is not possible on WinXP. Volume Shadow Copy service is started , also as Administrator.We get error message: Dateien, die Momentan im Gebrauch sind, können mit Volume Shadow Copy Service komprimiert werden. Aktivieren Sie bitte diese Anwendung bevor Sie die Dateien, die zur Zeit gebraucht werden komprimieren. Wenn Sie 7-ZIP-Kompression verwenden, führen Sie die Anwendung mit Adminrechten aus. |
| The Following User Says Thank You to mixmax For This Useful Post: | ||
spwolf (03-26-2012) | ||
did you try using VSS on some other computer, not only that one?
(so something is not wrong with Volume Shadow Service on that specific computer).
i have just tested VSS on an XP machine and it worked fine.
I tested both English and Multilingual versions...must be something specific. |
solved
I tried it on another WS and had the same problem. So I tried
to use Volume Shadow Copy with NTBackup and got BSOD. I found a link how to resolve the problem ( http://www.techspot.com/vb/topic94820-5.html ) After uninstalling all storgae volumes in device manager everything wored fine inclusive Power Archiver and open files. So I did it also on the first WS and here also everything went right. But I cannot get PACL V7 to work with VSS. |
spwolf (03-29-2012) | ||
Glad that's solved, thanks for letting us know.
What command are you using for PACL and it isn't working? |
PACL - used cmd
See the following output of pacl command
( open files ntuser.dat* are listed during command, but are not in zip-file ): D:\test>pacomp -uvss -a -w -k -r -p -c2 d:\test\arch-admin.zip "c:\Dokumente und Einstellungen\administrator\ntu*" PowerArchiver Command Line (PACL) Version 7.00 [Mar 22 2012] Copyright(c) 1998-2012 ConeXware, Inc. All Rights Reserved. Shareware Version Remainder: This is unregistered version of PACL. Please register at http://www.powerarchiver.com Press <ENTER> to continue. Archive Compression Utility -- ZIP,ZIPX,7-ZIP,CAB,LHA,BH,JAR,TAR,GZIP,BZIP2 Internet: http://www.powerarchiver.com Email: support@conexware.com Archive: d:\test\arch-admin.zip preparing to compress... adding: NTUSER.DAT --> Done. [0%] adding: NTUSER.DAT.LOG --> Done. [0%] adding: ntuser.ini --> Done. [0%] adding: ntuser.pol --> Done. [0%] All OK D:\test>echo errorlevel:0 errorlevel:0 D:\test>unzip -l arch-admin.zip Archive: arch-admin.zip Length Date Time Name ------ ---- ---- ---- 190 03-27-12 14:59 ntuser.ini 1282 03-27-12 13:52 ntuser.pol ------ ------- 1472 2 files |
New PACL:
http://www.powerarchiver.com/test/alpha125/pacl700.exe you will need to register pauac.dll via regsvr32 if you dont have PA installed on same system, for VSS support to work (it must register Activex dll with Windows).
| WinXP and Volume Shadow Copy | mixmax | Tech Support | 2 | 03-26-2012 09:36 AM |
| FTP and WinXP Scheduled Tasks | PalmettoHodag | Tech Support | 4 | 11-16-2009 08:10 PM |
| PA Outlook Issu WinXP | ACTANO GmbH | Tech Support | 6 | 03-02-2005 02:39 PM |
