-sep parameter broken?
I am trying to use pacomp with the -sep parameter to create a separate zip file for each source file. But when I specify a file mask that matches multiple files, only one zip file is created, for only one of the intended files.
Assume the current directory contains five .txt files. After running the following command, five zip files should be created: Code:
pacomp -a -sep ignored.zip *.txt Code:
pacomp -sep ignored.zip *.txt Result: In both cases only one zip file is created, containing one of the text files. Expected behavior: every file matching the mask *.txt should be compressed into an individual .zip file, so the example commands should create five separate zip files. Am I using the parameters incorrectly, or is it a problem with pacomp? I really, really need this to work
| The Following User Says Thank You to tranglos For This Useful Post: | ||
spwolf (03-02-2012) | ||
thanks fellas, writing it up!
Tested in PACL 7.00 RC1 and the sep parameter now works correctly.
Bug fixed confirmed Kind Regards Micke |
| SFX seems to be broken in 2009 | crohan | Tech Support | 7 | 07-24-2008 03:39 AM |
| 10.2 Broken Under Vista! | nwavguy | Tech Support | 3 | 10-05-2007 07:52 PM |
| Keep broken files? | snoggi | Tech Support | 0 | 06-13-2007 03:24 PM |
| PA Help SFX Option broken | amh209 | Tech Support | 1 | 11-29-2004 12:16 PM |
