Old 12-10-2011, 01:35 AM
AluminumHaste's Avatar
AluminumHaste AluminumHaste is offline
PA Super User
Can't register
I just got a new laptop and I installed PA 2012 on it, but when I use my 2011 pro legacy key PA just restarts then asks for registration again. I also tried my original 2009 key but that doesn't work either, if there a limit to how many computers I can register my copy of PA on?
EDIT: I think part of the problem is that I use too many computers. I work on 6 different computers throughout the week and they are all mine.
Old 12-10-2011, 03:27 AM
Sir Richard's Avatar
Alpha Tester III
Hi, PA doesnt to my knowlage have the ability to restrict the volume of times you use a serial. So i dont think its that which is the problem.
The best thing you can do is sign into Conexware account via the Support Tab on the new page this is called Order Recovery via; http://www.conexware.com/shop/
Within that you will be listed all applications you have Purchased licence's for and available upgrades with discounts.
You can also request for those serial codes to be resent to you and download the version specific to your license.
From the sound of things, you may need to upgrade so to use the latest version of PA as your free updates are limited to the last major version that incorporated Legacy. This can be clarified via your support page, and if you are still unsure you can email Conexware via the following;
http://www.powerarchiver.com/support/
Regards,
Sir Richard
Cheshire (UK)
NVIDIA Geforce GT 520MX
The Following User Says Thank You to Sir Richard For This Useful Post:
AluminumHaste (01-06-2012)
Old 12-10-2011, 08:05 AM
we dont check how many computers you have it installed on, there is no online activation/check.
You need PA 2011 codes for PA 2011. Make sure that you have English version installed in case you have purchased English version.
There is no PA 2012 :-). And only "Legacy" codes were for PA 2011, so you have PA 2011 codes, which makes me think that above language version might be the "problem".
The Following User Says Thank You to spwolf For This Useful Post:
Old 12-12-2011, 05:13 PM
got it figured out i trust?
Old 12-12-2011, 11:43 PM
PA Super User
Working on it lol. Checking right now.
Old 12-12-2011, 11:54 PM
PA Super User
You were correct I had accidentally downloaded the International version, I uninstalled it, got the English version installed and it worked.
The Following User Says Thank You to AluminumHaste For This Useful Post:
Mili (12-13-2011)
Old 12-13-2011, 06:02 AM
great! thanks...
Closed Thread
Register 7zip file ext rev23dev Tech Support 3 06-12-2010 07:46 AM
De-Activate/Register Serial key AluminumHaste Tech Support 1 06-22-2009 12:46 PM
Register for PC on multi-user systems mueter Tech Support 1 03-13-2006 10:11 AM
PA 2006 9.50 beta 4 does not register Claude Renaud Tech Support 4 09-07-2005 12:17 AM
