Error when using shell extensions and Total Commander
I'm using PowerArchiver since years and never had problems with this. Actually I'm using PA2011 with Windows 7 Home Premium x64.
Now I bought the program Total Commander and every time I rightclick on a file or a folder Total Commander is crashing down. With ShellExView I tried to disable all shell extensions which are not from Microsoft. So Total Commander did not crash any more. But after enabling the shell extensions from PowerArchiver Total Commander crashes down when right clicking. Is there any possibility to fix the shell extensions so that Total Commander works without crashing down?
Cu, PoooMukkel |
is TC 32bit or 64bit? Problem might be our 64bit shell extension then?
ok, so I tried:
PA 2011 12.01.03 Int TC 7.56a on Win7 64bit. All works fine... both 32bit and 64bit shell ext work fine, and even UAC elevation works as advertised. Maybe you are using different version of TC or PA? If not, maybe some PA setting is different? Send us your settings via Options> Save (7z first), to support at conexware dot com and refference this thread... thanks!
I'm using TC 8.0 beta 7 x64 with PA 2011 12.01.02 GER.
Saved my options, zipped the reg file and sent this to you... Best regards, PoooMukkel
Cu, PoooMukkel |
did you try reporting this to them? This seems to be the issue with their 64bit TC that just came out. Same PA works fine in their official release.
Keep in mind that this is first release of Delphi 64bit, so these issues will arise.
Yes, I reported this to them. But they said that it must be a shell extension which works not correctly. So they put me to ShellExView and I disabled all of the non-Microsoft extensions. Then I enabled them one by one and tested with TC.
Cu, PoooMukkel |
it worked fine in 7.65a, it works fine in Explorer... just doesnt work in their betas and new 64bit code :-).
Ok... That's a fact...
![]() By the way I tested WinRAR and their shell extension works fine with the beta of TC. I don't know what to do now. I asked again in the forum from TC. Hopefully there will be a fix.
Cu, PoooMukkel |
tell them it works fine in official release, just not in their new 64bit release, and that works fine in x64 Explorer.
Okay, I will try...
Cu, PoooMukkel |
#11
anything?
#12
Sorry for letting you wait...
I asked the support from Total Commander. TC is only using 1 function for shell extensions. The rest is made by Windows. So they are not able to help. ![]() But they showed me some workarounds for the problem. One is to use the x86 version of TC. Then it will work. Or using the x86 shell extension from PowerArchiver should also work. But I don't know how to use the x86 shell extensions because I don't have the possibility to install x86 version of PA on x64 system. May be you can do something in one of your next versions with the shell extensions? That would be great.
Cu, PoooMukkel |
#13
did you have any luck with this?
#14
No, I didn't have. I'm waiting for another version of PowerArchiver. Hopefully the shell extensions will work then...
Cu, PoooMukkel |
#15
you can unregister x64 bit shell extensions, will that work?
#16
What does that mean? And how can I do that?
Cu, PoooMukkel |
#17
I don't know, how to unregister x64 shell extensions...
Installed PowerArchiver 2011 V12.10 but shell extensions still not work with Total Commander 8 Beta x64.
Cu, PoooMukkel |
#18
Go to cmd.exe
and run: regsvr32 /u PASHLEXT64.DLL it will unregister 64bit shell extensions!
#19
That does not work. There appears an error which I only have in German.
Cu, PoooMukkel |
#20
you need to navigate to PA folder first, or else specify the path before... like C:\program files (x86)\powerarchiver\pashlext64.dll
| The Following User Says Thank You to spwolf For This Useful Post: | ||
PoooMukkel (01-11-2012) | ||
#21
After that there are no shell extensions from PowerArchiver available although I checked the box in the settings.
Cu, PoooMukkel |
#22
but you should have 32bit ones in TC? PA installs both x86 and x64 shell extensions.
#23
No. There are no extensions from PA after that.
Cu, PoooMukkel |
#24
run this:
%windir%\SysWOW64\explorer.exe /separate, /root, c: do you see PA shell there now?
#25
Still no shell extensions from PA.
Cu, PoooMukkel |
#26
May be did you change something in PA2011 12.11 to solve this problem for me?
Cu, PoooMukkel |
#27
No... It still does not work.
Cu, PoooMukkel |
#28
PoooMukkel,
Sent you a PM
#29
bumping this thread again, should be fixed in .22
let us know |
| Ciritical: Power Archiver 2010 & Total Commander, odd extracting behaviour | menes | Tech Support | 9 | 05-19-2009 01:32 PM |
| PA shell extensions missing in Total Commander | crunch | Tech Support | 4 | 03-12-2008 09:43 AM |
| Total Commander SQX 1.10 | TBGBe | Tech Support | 4 | 03-01-2007 01:25 AM |
| 7z shell extensions | davidsplash | Tech Support | 10 | 12-18-2004 04:22 PM |
