I just wasted half of a day with Antimalware support because of Powerarchiver.
![]() After installing the Microsoft Security Essentials (MSE), with each boot MSE logs the following warning: Name: Behavior/ModifiedKernel ID: 2790572135 Description: http://go.microsoft.com/fwlink/?link...tid=4294967289 With this, MSE also logs a random filename in the shape of "sp??.sys" that DOES NOT EXIST on the system, like "spco.sys" or "spla.sys". This made it extremely difficult to find out what was wrong. I finally found out that PowerArchiver installs the driver Windows\system32\drivers\SPTD.SYS, and this driver disguises itself with a random name on each boot. I also managed to find the company Duplexsecure, maker of SPTD. They offer a download to update or uninstall SPTD: http://duplexsecure.com After uninstalling SPTD, MSE finally is calm. I hope this thread helps other people with the same problem. I wonder why PowerArchiver installs disguising stuff? At least there should be a warning about possible consequences for Antimalmare software. So far I could not find any negative effect on PowerArchiver after uninstalling SPTD. Last edited by Kai Fieabach; 09-14-2011 at 08:55 AM. |
| The Following User Says Thank You to Kai Fieabach For This Useful Post: | ||
spwolf (09-14-2011) | ||
I would say it's a problem with MSE rather than Powerarchiver. False positives happen from time to time with malware and antivirus software. Best to report it to them.
Vista home premium SP2. Always the latest Powerarchiver Toolbox |
| The Following User Says Thank You to Luxor For This Useful Post: | ||
I do not regard this as a false positive. If a software disguises itself with false file names, so that it cannot be detected, and gives "signs of tampering in the state of the running operating system kernel" as SPTD does, I am thankful for a warning of Antimalware software. I still do not understand why Powerarchiver installs disguising drivers. When I bought Powerarchiver, I expected clean software, not something that hides and behaves like a root kit.
It is best if you report it to MSE and we will also do the same. They usually fix false positives quickly.
btw these are the drivers that get installed with Virtual Drive, they allow for direct access to burner devices, and they are much better to use than standard Windows SPTI.
PowerArchiver Burner can use: SPTD, SPTI or ASPI for burning drivers, but SPTD is by far the best of 3 and recomended for fastest operation and least number of issues.
| Tags |
| duplexsecure, malware, sptd.sys, uninstall, virus |
| Missing SPTD driver after PAVD install | Keith Weisshar | Tech Support | 7 | 01-11-2012 07:37 AM |
| [BUG] PA 11.60.22 triggers "Windows - No Disk" error on startup | welhaux | Tech Support | 18 | 10-25-2009 03:50 AM |
| Antivirus Warnings | spiker19 | Tech Support | 6 | 02-01-2006 06:10 PM |
| warnings that paths not extracted | davidsplash | Wishlist | 3 | 10-26-2005 05:41 AM |
