Go Back   PowerArchiver Forums > PowerArchiver 2012 > Wishlist
Old 10-16-2010, 10:38 AM
i_am_jim i_am_jim is offline
Junior User
Let User Add Subfolder to SFX Extract Folder
An earlier version of the program let me add a subfolder to the default Temp folder PA extracts an SFX file to. As it is PA dumps all the files into the top level Temporary folder and, in my opinion, makes a mess.
Also, I have occasion to ask users of my product to find a particular file in the extracted set. It makes this much easier if they are all in a unique folder with a name of my choosing.
If this feature exists please point me to it.
Old 10-16-2010, 01:57 PM
did you try %temp%\name?
(check for actual alias usage in help file, been while since i checked that out)... it should work fine!
Old 10-16-2010, 04:38 PM
Junior User
That's how the older version I was using worked. In the current version the extract location is chosen from a dropdown and you can only choose from fixed options. None of these three options has a subfolder.
My search of Help found no reference to the word alias and only one to the word actual and it was not on topic.
Old 10-16-2010, 04:56 PM
Junior User
Another way to do this is to use the archive name as the subfolder name.
I can see the possibility of conflicts this way but it most probably works.
Old 10-17-2010, 04:01 AM
here is the help:
conext sensitive help (press help in Make SFX window):
"Default "UnZip To" folder" - This is the default folder in which the extracted files will be placed. If you select "Use TEMP directory", the files will be extracted to the default Windows temporary directory. Click here for more info on advanced extract path options.
and then click here leads you to this:
Predefined extraction paths can be entered in either the Make SFX or SFX Wizard "Default UnZip To folder" field.
Extraction Path Options
Constant Description Typical or Example Path
%temp% User's temporary folder C:\WINDOWS\TEMP
%temp-unique% A unique temporary folder C:\WINDOWS\TEMP\~SFX345A
%win% Windows Directory C:\WINDOWS
%winsys% Windows System Files Directory C:\WINDOWS\SYSTEM
%PROG% Program Files Folder C:\Program Files
%DOCS% User's documents folder C:\My Documents
%DESKTOP% User's Desktop Folder C:\Windows\Desktop
%FONTS% Fonts Folder C:\Windows\Fonts
You can also use registry entries. In this case, use the pipe symbol ( | ) to create sub-folders.
Examples
Default UnZip To folder: %prog%\PowerArchiver\Skins
Typically: C:\Program Files\PowerArchiver\Skins
Default UnZip To folder: %temp%\~test
Typically: C:\Windows\Temp\~test)
Default UnZip To folder: HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Com monFilesDir|MySoftware
Typically: C:\Program Files\Common Files\MySoftware
Old 10-17-2010, 11:04 AM
check example here
Old 10-17-2010, 01:24 PM
Junior User
Okay. I think I've got it. It never dawned on me you could type in the dropdown items. And even if it did I wouldn't have thought it understood relative paths.
Thanks very much for your help.
But, that leads to a new question. A caution in this help area says:
Important information on using "run command line after extract" option
In case you are using advanced extraction path option together with run command line after extracting option, you will need to use special "{p}" option in the run command line after extracting field so you can tell PowerArchiver SFX where to find extracted files.
Example
Default UnZip To folder: %temp-unique%
Run Command Line: setup.exe
Explanation: These options will run setup.exe from temporary path noted above.
I do run a setup program after unzipping. But, I don't understand these instructions.
I don't understand what a {p} option is. If my extract-to folder is FOOBAR it looks like I would use:
Default UnZip To folder: %temp%\FOOBAR
But, I don't see how that's added any {p} option?
Old 10-17-2010, 01:27 PM
if you do just setup.exe, it will run setup.exe and thats it. If will run whatever is first setup.exe on that system in system path... if you do {p}\setup.exe, it will actually run %temp%\FOOBAR\setup.exe.
Old 10-17-2010, 01:38 PM
Junior User
deleted
Old 10-17-2010, 01:40 PM
no, you can add it if you want.. it doesnt add it automatically, it is optional and up to you.
so use {p}\setup.exe and it should be fine.
  #11
Old 10-17-2010, 01:49 PM
Junior User
I'm still not sure I get it.
If I use:
It will run setup.exe in the %temp%\FOOBAR folder. But, if I use {p}\setup.exe it will do something else???
All I use PA for is to dump the files in a folder named FOOBAR under the default Temp directory and start Setup.exe in the folder FOOBAR and quit. Setup does the rest.
  #12
Old 10-17-2010, 02:00 PM
Run Command Line: {p}\setup.exe
is what you should use... it runs specific path command line to where your executable is.
  #13
Old 10-17-2010, 02:01 PM
p.s. just try it yourself and see if it works fine for you!
  #14
Old 10-17-2010, 02:37 PM
Junior User
That's what's confusing. Not using (leaving out) the {p} seems to work fine. If I just use setup.exe, PA creates the subfolder and extracts the files into it and launches setup.
Thank you very much for all your help.
I still wish I could understand how adding the {p} is different than not adding it.
  #15
Old 08-17-2011, 03:10 PM
wilsonp wilsonp is offline
Senior Members
I think the problem is the example in manual is wrong since it doesn't use the {p} option but is supposed to be an example of how to use the {p} option.
I found this incredibly hard to decipher, and really don't understand why SFX wouldn't run the command line in the root extracted folder, especially when you set something like the default extract to temp folder.
This could do with a lot of improvement, and better documentation.
Direct extract without temp folder masu Wishlist 20 05-11-2009 06:43 PM
Shell Option "Extract to subfolder" hangs PA TBGBe Tech Support 3 11-20-2007 08:03 AM
How do I: extract to file name, multiple archives in a user defined directory wulffra General 13 03-13-2005 06:17 AM
