Old 02-26-2010, 01:34 AM
wilsonp wilsonp is offline
Senior Members
Smile Virtual Drive improvements
It would be really nice if there was a unmount option on the virtual drive like Virtual Clone Drive supports to unmount. Or see the complete context menu options Virtual Clone Drive has, including the ISO filename. If the Eject option did it, that would be even nicer. Also, why does Win7 x64 show a Close Tray option on the virtual drive?
It would be nice if the wizard didn't come up (or wasn't implied as being needed by the Mount as Virtual Drive... menu option) and the ISO just mounted.
It would be really nice if the UAC didn't come up for mounting/unmounting the ISO - Virtual Clone Drive doesn't have this issue.
Also, shouldn't the unmount pop-up box actually list the drive/ISO information that is being unmounted?
And I wish the installer had given me an option to install PAVD, or at least the registration process. I don't normally launch PowerArchiver as a stand alone application. A separate burner interface would be good, too.
PS The Edit post interface should let you edit/add tags too.
Old 02-26-2010, 02:40 AM
moles42's Avatar
moles42 moles42 is offline
Alpha Tester
if you're a windows 7 user then this thread maybe useful to you in regards to mount/unmounting virtual drives.
http://www.powerarchiver.com/forums/...=virtual+drive
of course there's always the PASTARTER.EXE option you can use.
Mike
Windows 7 Ultimate x64
Intel Core 2 Duo E6850 3.00Ghz
nVidia GEForce 8600 GT
4.0 Gig Ram
The Following User Says Thank You to moles42 For This Useful Post:
spwolf (02-26-2010)
Tags
iso, pavd, virtual drive
11.50.57 & Virtual Drive moles42 Tech Support 3 07-07-2009 08:00 PM
Virtual Drive moles42 Tech Support 6 05-19-2009 08:00 AM
Virtual Drive enhancements/improvements wulffra Wishlist 4 01-19-2009 02:12 PM
Virtual Drive itbytes Tech Support 2 07-26-2008 10:01 AM
