What format next? December 2009
I am writing an blog entry where you will be able to select what format you want next to be added in PA.
Need a list of suggestions to be added. Some suggested so far are: - 7zip LZMA2 - ISO (UDF, not supported now) - MSI - EPUB (variant of zip format for publishing books) .... more? Add your suggestions as soon as you can. We will make an blog post about it and you will be able to vote. p.s. everyone with forum account can automatically comment and vote on blogs, it is all integrated!
Required for possting suggestion is that there is an thread with better explanation on forums, and you can refference it here.... if there is no thread for format you want, create it and then refference it here!
Is there any restriction for implementation or can we request full (both extraction and compression) support?
... (waits for multiple RAR compression requests).
Terry WinXP SP3 |
extraction first...
i wont bite i promise ;-)
Sorry, mis-read your post and was waiting for blog before voting.
Seems you want additional suggestions for your blog so:- SQX (but NOT without recovery record support )NRG (disk format)
Terry WinXP SP3 |
need more suggestions before we select what will be votable ;-)
"keep broken files" on rar.
Windows 7 x64 (NLD/ENG), I5-760 |
thats the spirit ;-)
Simple binary splits with extensions 001, 002, etc. Only joining is fine.
I know it's not an archive, but 7-zip can join them, so why not. |
#11
you mean HJSplit? If so, a +1 for me.
#12
That seems to be the most popular "graphical" tool. The good old DOS command is as follows:
Code:
Copy fileA+fileB fileC |
#13
peachy! more, more!
#14
so far:
- 7zip LZMA2 - ISO (UDF, not supported now) - MSI - "keep broken files" on rar. - Join split files (ie HJ Split)
#15
vetoed SQX, as to the NRG, they are not supported right now? Or is there something new now?
#16
faster extraction of .IMG files
#17
O man that would be great if PowerArchiver could do what "HJSplit" does!!
![]() Also "Keep Broken Files" for RAR would kick ass! Please add both of these options soon!!! |
#18
Option to remove PowerArchiver right click context menus from the Start Menu and All Programs menu!!
#19
And my number 1 request is just too make everything about PowerArchiver FASTER!!!!!
#20
i will let you self moderate above two posts - this is the thread about specific issue - what format next in PA. This is not mother of all threads about PA. If you have additional wish, post it in its own thread but first look for other similar threads (both above already have them).
#21
Re: SQX Vetoed
Hello, because you vetoed SQX. I'd like to know why. I know i can add this Format via the TotalSQX plugin. But native i think would be better because you could also Implement the Compression in this Format (later) easyly. Or if you don't want to add this format directly you could in one of the next versions extend the Plugin-Interface to allow the creation via the Plugin (witch the plugin allows). you just had to create a button were you could configure the settings.
Best Regards, TWPhoenix aka R. Landscheidt Last edited by twphoenix; 12-19-2009 at 02:54 PM. |
#22
#23
Best Regards, TWPhoenix aka R. Landscheidt --------------------- -Windows 7 pro -Powerarchiver 11.61 Pro -SpeedCommander 13 -Squeez 5.63 -WinRAR 3.91 Last edited by twphoenix; 12-19-2009 at 03:28 PM. |
#24
Is Squeez discontinued? I can't find its page.
#25
Mike +--------------------+ Windows 7 Ultimate x64 Intel Core 2 Duo E6850 3.00Ghz nVidia GEForce 8600 GT 4.0 Gig Ram +--------------------+ |
#26
No, SpeedProject homepage.
http://www.speedproject.de/enu/index.html |
#27
sorry...my mistake..
#28
Re: Squeez
Yes. Sadly. Here are some infos:
http://blog.speedproject.de/2009/08/...-teufelskreis/ (German Only - Sorry i found only Information Availible in German) But you can still download the Latest Version via the Update Page (http://www.speedproject.de/support/updates.html). But you can't buy the codes for this anymore. But the Compression Engines are also in SpeedCommander. So you can still use the SQX Compression and the Other Compression Formats. Best Regards, TWPhoenix aka R. Landscheidt ----------------------- -Windows 7 Pro -Powerarchiver 11.61 Pro -SpeedCommander 13 -Squeez 5.63 -WinRAR 3.91 Last edited by twphoenix; 12-20-2009 at 10:13 AM. |
#29
I would like to see 7zip support put as a command line plugin so it is always up to date with the latest 7zip specification some other archivers do this why not powerarchiver
#30
you want 7zip to be command line? That makes no sense... we dont have support for lzma2 yet, because it is not in its finalized form. We can not offer it before Igor tells us it is safe to do so.
| archive format | davidsplash | Wishlist | 3 | 11-17-2009 05:38 AM |
| SQX Format | twphoenix | Wishlist | 3 | 10-28-2009 05:28 AM |
| 7-zip, PowerArchiver (December, 2008) | jcarlock | Tech Support | 3 | 06-19-2009 08:27 PM |
| SQX format support | guruman | Wishlist | 13 | 03-16-2006 03:00 AM |
| UHA format | freeman | Wishlist | 1 | 03-07-2006 10:47 AM |
