Closed Thread
Old 12-03-2009, 01:36 PM
Wepver Wepver is offline
PA Super User
Default Classic skin's "Start menu" bug
“Options/Include PowerArchiver in the Start menu” is unchecked despite it was already installed during the program installation. If you check it then an extra Power Archiver entry appears in the Start menu (this only happens once = 2 Power Archives on the Start menu) and when you re-open PA it remains unchecked again. If it was not selected to add one shot cut in the Start menu then it does not create a duplicate one, but the second problem still persist. (It is impossible to remove by the use of PowerArchiver. You have to delete it manually.)
Old 12-04-2009, 08:11 AM
mili logged it yesterday... we will update once we get status change... thank you!
Old 02-02-2010, 05:35 PM
Please check if following pre-release fixes the issue:
http://www.powerarchiver.com/test/re...warc116202.exe
and let us know... thank you!
Closed Thread
Option to make default for "don't extract pathnames" seamoon Wishlist 0 07-12-2009 05:12 PM
miss an option to disable "run PA Starter on windows start" masu Wishlist 6 03-09-2007 12:54 PM
"archive properties" context menu voice manuangi Wishlist 13 05-24-2006 04:03 AM
