Old 12-02-2009, 05:00 PM
drteeth's Avatar
drteeth drteeth is offline
PA Super User
PA and Kaspersky 2010
When Win 7 was in beta as well as Kaspersky anti-virus (KAV), I reported an issue where PA took seconds to close. It turned out to be a reaction between the two programs and the situation improved with a KAV update.
The problem is back with the release of KAV and only affects PA here.
When PA is trying to close, the quick access toolbar is replaced by "zna (not responding)" - screen shot attached.
Is there anything you can do? I'm prepared to leave KAV if you cannot or it is too much trouble.
Cheers
DrT
Stress - the condition brought about by having to resist the temptation to beat the living daylights out of someone who richly deserves it.
Old 12-03-2009, 07:00 AM
Mili Mili is offline
Moderator
Kaspersky has been notified as other users of the curretn have reported the same issue with Kaspersky.
We're hoping they'll take care of it.
Old 12-03-2009, 10:14 AM
we are trying to contact them about the issue so they can fix it... apperantly, KAV does not like PA writing the registry, this is what is being slowed down, even if you turn off KAV (but leave it installed) or whitelist PA.
Old 12-03-2009, 03:32 PM
drteeth's Avatar
PA Super User
SOLVED: PA and Kaspersky 2010
That's what the registry is for, to be written to (amongst other things). I'd be VERY interested in how Kaspersky deals with this...I do not want to deal with a company that cannot fix issues with other software.
Regards
DrT
UPDATE: issue seems to have been fixed with latest hotfix. It's the 'b' in the attached shot...need to reboot to apply it but Kaspersky will not request it.
Old 12-09-2009, 07:57 AM
cool
Old 12-18-2009, 06:58 AM
markdigi markdigi is offline
Senior Members
Hangs and CPU 100% on Close Win7
Hey all,
I'm not too sure about this problem really, it would seem my Powerarchiver (im on the latest version) has a problem with closing or shutting itself down.
When extracting via shell or opening the program everything runs fine.
However when I click the "Close" X button instead of closing instantly it hangs for about 20second, going into not responding. I also noticed after clicking close the CPU maxed out at 100%.
Any idea what this might be? Im running Windows 7 and latest versions, dont think I had this issue when was running it on XP. Are there any "cleanups" or "unloading" processes that it runs though when its closed that could be showing it down?
Anyways hope you can fix as it is slowing down the process of jumping in and out of multiple zip files.
If you need any more info or if anyone else has found this please say.
Old 12-18-2009, 07:29 AM
infimum infimum is offline
PA Super User
No such problem on my Win7 32bit.
You could run Process Monitor to see what is going on.
http://technet.microsoft.com/en-us/s.../bb896645.aspx
Cheers.
Old 12-18-2009, 08:30 AM
Moderator
Also, which anti virus software are you running?
Old 12-18-2009, 08:55 AM
also send us your reg key at HKCU\Sotware\PowerArchiver, zipped, to support at conexware . com.
Old 12-18-2009, 09:00 AM
Senior Members
Im running Kaspersky Internet Security 2010 however the problem still happens when this is closed/exited/completly unloaded from the processes.
As for process monitor this revealed alot more information. I could post the output if requested but it is a bit long. However from the looks of things the it looks like its accessing and changing a lot of registry values.
Mainly the subkeys for Stats, Columns, General, Shellex and Profiles are being accessed/edited . From start to finish the close time on the program is 35 seconds.
  #11
Old 12-18-2009, 09:04 AM
You need to update Kaspersky to patch b I believe and then restart your computer. Their patch b fixed this issue with PowerArchiver.
  #12
Old 12-18-2009, 09:52 AM
Senior Members
Nope, already have that patch installed, its also a note that this issue has been across the last couple of powerarchiver versions and i suppose the last couple of antivirus versions as well, all of which auto update.
I have sent an email to the support inbox (ref 4370 for quickfind) with the reg keys and the process manager log files for powerarchiver processes from when the "Close" button is pressed. Hope they help.
  #13
Old 12-18-2009, 10:00 AM
yeah, and Kaspersky fixed that issue last week ;-). Are you sure you restarted your computer after installation? Because Kaspersky update wont be completed until restart is done.
What language version are you using? English?
  #14
Old 12-18-2009, 10:02 AM
merged with previous kaspersky thread...
  #15
Old 12-18-2009, 10:12 AM
Senior Members
Yep, restart it daily, it seems like the same issue tho, even from the log files with the registy and kaspersky being turned off, I noticed the zna thing after saw the screenshot too.
Yes Im on the English version 9.0.0.736(a.b) however the only diff I could see would be that I am running Kaspersky "Internet Security" rather than just the antivirus although version numbers are identical
Guess the issue should be re-raised with them then...
  #16
Old 12-18-2009, 10:20 AM
you can not turn off kaspersky as easily as that - you have to uninstall it for it to not work... So even if you "turn it off", or whitelist PA, it will cause still the same issue.
We have had users reporting it for Internet Security as well, and they said it has been fixed.
Maybe it got "broken" again? drteeth are you having issue with kaspersky again?
  #17
Old 12-18-2009, 10:24 AM
i will ask these users that reported it to support as well, to see if Internet Security has been fixed, or maybe that was not fixed originally.
  #18
Old 12-19-2009, 06:02 AM
drteeth's Avatar
PA Super User
Still okay here.
DrT
Tags
hangs, powerarchiver, shutdown, win7, windows7
Closing PA 2010 under Win 7 drteeth Tech Support 21 07-03-2009 05:42 PM
Kaspersky Internet Security setup in Powerarchiver ? triflow Tech Support 3 06-05-2009 12:31 AM
PA 2010 b1 drteeth Tech Support 5 03-04-2009 09:43 AM
Kaspersky configuration. doron_amedey Tech Support 3 12-31-2006 05:13 PM
Kaspersky Antivirus v6 andyr2005 Tech Support 5 09-28-2006 02:17 AM
