I have a PowerArchiver backup script created and scheduled via XP's Scheduled Tasks. I set up an FTP profile in PowerArchiver so the script will send the file to my NAS. PAbackup creates the 7zip file in the temp directory just fine, but fails to ftp the file, giving the "Error uploading file..." message. However, I can then go to the temp directory, find the 7zip backup file, right-click, choose "PowerArchiver 2010","FTP it", and select the *same* PA ftp profile and the file gets sent just fine. Why would PA FTP Quick Connect work but not the same profile within PA? I am using the latest official build of PA 2010. Greg |
Please send us the PBS script you are using and a screenshot of the FTP profile
you can send it to support at conexware dot com Thanks! |
Ok . . . thanks Milli.
Greg |
Here you go:
http://www.powerarchiver.com/test/re...warc116104.exe let us know if it has been fixed. Thanks!
FTP Issue Fixed
Thanks SPWOLF,
That update seems to have fixed the problem. Greg |
