MACRO/BATCH Request:
i got a folder named COMPRESS
i got *.xls and *.doc files in there how can i make just compress xls and doc extensions in their separated file names with One click to a folder? do i have to make subfolders for this operation to batchzip? file name samples: dailybackup09062009.xls dailybackup09062009.doc dailybackup09072009.xls dailybackup09072009.doc i want this at the end of compressing: (xls and doc files in it) dailybackup09062009.zip dailybackup09072009.zip how can i compress these files with xls & docs in their separated filenames please help |
Sorry, I don't understand what you mean by "One click to a folder" as PACL is a command line utility ?
a) use the option "sep" will give you dailybackup09062009.xls.zip dailybackup09062009.doc.zip dailybackup09072009.xls.zip dailybackup09072009.doc.zip b) If your files are named as stated then you could create a DOS batch file/command something like For %%I in *.doc do pacomp -a %%~nI.zip %%~nI.doc %%~nI.xls This results in dailybackup09072009.zip containing dailybackup09072009.doc and dailybackup09072009.xls Check the actual syntax for your version of Windows with "HELP FOR"
Terry WinXP SP3 |
i mean, i right-click to a folder files in it then voila.
how can i use pacomp ? through the PowerArch GUI? i want program to automaticly select *.xls and *.doc and archive them separated by their unique file names. dailybackup09062009.zip files to their own dailybackup09072009.zip files to their own archives (xls and doc extensions) in it. how can i ? i couldnt make it with Winrar
I think this is in the wrong forum, you seem to be asking about PowerArchiver and not PACL.
a) create a single archive (compress.zip) containing all files b) create seperate archive for each file in the folder using the "batch" option Creating seperate archives based on matching filenames (but different extensions) is not possible. If I understand your requirement you will have to create a Backup Script using PowerArchiver - but don't create a new doc and xls each day, just update them and then run the script daily and backup to an archive named using the date.
Terry WinXP SP3 Last edited by TBGBe; 10-01-2009 at 10:42 AM. Reason: Edit: I moved the thread in PowerArchiver Support |
thanks TBGBe for your concern
