Go Back   PowerArchiver Forums > PowerArchiver 2012 > PowerArchiver Blog
Old 08-25-2009, 07:08 PM
PowerArchiver 2010 11.60 Preview - Whats New?
Here is the list of changes for PowerArchiver 2010 11.60 Preview release:
Version 11.60.08 [August/2009]
New Features
* Support for extracting ZIPX JPEG format, PowerArchiver becomes only application after WinZip 12 to fully support ZIPX format.
Improvements
* Memory usage improvements - up to 1 MB less memory used.
* Faster explorer view.
* PA uses ZIP as default compression when PA has not been run.
* Spanning now enabled when Queue is used.
* Improved Burner engine.
Bug Fixes
* #1536 - Issue with compressing unicode files in non-english Windows (such as Chinese versions of Windows).
* #1533 - File format selection resets when open dialogue is used to select new filename.
* #1501 - FTP profile selection in backup gets reset.
* #1524 - Issue with 7zip and encrypt filename option.
* #1520 - Spanning is available when PAE encryption is selected.
* #1521 - Update save window does not always default to my documents.
* #1517 - Some Pro options still available when registered as Standard license.
* #1525 - Mount Virtual DVD option not showing up in shell.
* #1507 - Other PA settings not saved if PA is restarted after registration.
* #1513 - Right click menu not showing in backup list.
You can download this release from our download page. Thank you!
