Old 06-19-2009, 03:38 PM
jcarlock jcarlock is offline
Senior Members
7-zip, PowerArchiver (December, 2008)
Trying to zip up a bunch of HTML files into a 7-zip file, I noticed that PowerArchiver 2009 (version 11.03.04 12/2008) changes the case on all the file names. On a Linux system, where the OS recognizes file1 as a different file from File1, this turns out as a problem. Now I'm distributing HTML files, all with like names, and I know that because I created the files on a Windows OS, I won't run into any problems, but if someone else ever updates the files and uses names where the case of the file name ends up as a requirement, PowerArchiver, in general, may run into problems.
I'm surprised Microsoft has not already changed the OS to recognize the case of the file name and folder paths.
Also, I noted that PowerArchiver does unzip them to the proper case. It just fails to display the proper case of the file names while displaying them inside of the PowerArchiver application.
I'm not currently complaining, just passing along some information that needs to get looked at for a 100% bug-free product. Thank you for your time.
Old 06-19-2009, 05:24 PM
Senior Members
An hour or two later, another browser gets logged out. I believe you other guys put a check mark into the box that says "Remember me". I'm going to stick with my original comments that I get logged out after 10 or 15 minutes. This seems proper and probably ends up as the best value for such things.
The time could be made a little longer if someone working on the website cares to worry about it. Those doing the PHP programming should know what I'm talking about and understand all this, if anyone wants to pass on a suggestion to them, I think 20 or 30 minutes at most, but that's my own personal thoughts on the topic.
This does not represent a complaint. Thank you for passing this on to those that do the PHP programming.
Old 06-19-2009, 08:25 PM
it is just standard vbulletin preset (our forum software). If you want it to remember you, you need to select remember option.
Old 06-19-2009, 08:27 PM
can you attach an example file please? Works fine here, it might be some option you selected in PA.
I just want to doublecheck with your example first.
thanks a lot.
