Slow startup
Could somebody let me know the minimum system specs for the latest RC1? I installed it on a laptop, whilst not the most stellar of machines, where it took 29 secs for the main window to appear. Machine is defagged, running clean and lean. OpenOffice Writer 3.1 is ready to use in 20 secs.
Celeron 2.6GB, Win XP, 496MB of ram just over half that used for cache, the rest free. Cheers DrT
Stress - the condition brought about by having to resist the temptation to beat the living daylights out of someone who richly deserves it. |
use classic view, classic skin... hows that now?
Exactly the same.
Cheers DrT
is PA registered? if so, clear registration info and check then (so it is unregistered). lets see what happens now.
I can clear the reg info, but not save the change. Clicking OK gives an error and the info returns. I can close the box by clicking the 'X' (top right) but PA remains registered.
Cheers DrT PS Issue still present in RC2
delete your HKCU\Software\PowerArchiver key...
WOW
![]() ! 7-8 secs until the screen telling me how many days left of trial to run, under which the PA program was seen! How do I get that 7-8 secs startup with PA being registered? 29 to 8 secs startup is not to be sneezed at. Cheers DrT
Stress - the condition brought about by having to resist the temptation to beat the living daylights out of someone who richly deserves it. Last edited by drteeth; 05-28-2009 at 04:10 PM. Reason: removal of erronious information |
we start by giving me an headache and then we move on
we have tried on our Turion and it starts within 4 seconds.
Are you sure the difference isnt because of it being cached in memory 2nd time you try?
Cheers DrT
#11
Nice to know it isn't just me. I noticed that PA was not as quick as it was at loading when 2010 was first out in beta...and a fast(er) load was one of its plusses.
Cheers DrT
#12
How many files/folders are there in folder where startup is slow?
#13
No difference here at all with that change to a fixed folder.
Cheers DrT
#14
yeah, as i said, it is two completly different problems.
#15
There has to be something in that startup folder thats causing it...
#16
and if archive is in startup location (thats what i meant, location where PA Starts), same? What Antivirus are you using? It seems to be scanning the file before letting PA use it?
#17
#18
only difference in using last open archive as startup folder is that is starts in different folder than what you manually set, PA doesnt do anything else.
#19
HKCU\Software\PowerArchiver and zip it before sending. That will help us replicate this exactly. thanks!
#20
Got it... nothing special we could see from that.
Lets check this. Create folder C:\1. Copy those zip files that you have in folder thats slowing down PA startup to C:\1. Now set PA to start in C:\1. Is it slower now as well? If it is slower, remove file by file from C:\1 and see if you can pin point what exactly is slowing it down. Doesnt that make sense? thanks
#21
When was the last time you restarted that computer?
#22
I restart it on a daily basis...
Fafner |
#23
Any news on this issue since I reported back on the test file?
Cheers DrT
#24
#25
Cheers DrT
