Go Back   PowerArchiver Forums > PowerArchiver 2012 > Wishlist
Old 07-18-2004, 04:11 AM
klumy klumy is offline
Senior Members
Exclamation Extract here Bug with spanned archive - severe bug
If I mark several spanned archives in the explorer and try to use the "Extract here" function of the Explorer contextmenu, PA always says "please open the first part of the spanned archive", if it tries to open the part of the archive which is not the first part.
PA should be able to auto. recognize spanned archives, although the opened archies is not the FIRST archive of the spanned archive set like in WinRAR.
PowerArchiver 2007
Windows XP SP2
Old 07-18-2004, 05:41 AM
How is this an severe bug? First of all, it only happens in PA 6.xx spanned archives, which have all of the files marked as .zip (which is also why newer zip spanning formats dont), and I PowerArchiver does tell you where the issue is.
If anything it should go to the wishlist, since it would be an new feature, but hardly an earth shattering bug.
Old 07-18-2004, 05:55 AM
Senior Members
thanks for the fast answer spywolf
It's not just happens on spanned ZIP archives, also on spanned RAR archives. PA says, where the issue is, but it is still annoying to click away all those dialogboxes, especially if you have selected a large amount of spanned archives.
PowerArchiver 2007
Windows XP SP2
Old 07-18-2004, 06:08 AM
What happens when you select only one file/spanned archive?
Old 07-18-2004, 06:20 AM
Senior Members
The same.
If I want to open a spanned archive like
CR.part7.rar
CR.part2.rar
CR.part3.rar
CR.part4.rar
CR.part5.rar
CR.part6.rar
CR.part1.rar
I always have to select the first one for the "Extract Here" Command.
In this case
CR.part1.rar
It would be good, if it is uninportant which part you select, that PA can auto. see, that e.g. part 6 and part 3 are part of ONE spanned archive.
PowerArchiver 2007
Windows XP SP2
Old 07-21-2004, 10:13 AM
manuangi's Avatar
manuangi manuangi is offline
bumping angel
yes, I second klumy's request...and guess this is a bug and the thread should be moved to the proper section..
ANGELICA
Old 07-21-2004, 10:32 AM
The same.
CR.part7.rar
CR.part2.rar
CR.part3.rar
CR.part4.rar
CR.part5.rar
CR.part6.rar
CR.part1.rar
In this case
CR.part1.rar
It was actually planned for 9.0, and was working fine in earlier alpha's, I will see with Ivan why was it taken out of the final versions... (ability to select any rar multivolume and PA would automatically open first).
Old 07-21-2004, 11:12 AM
Senior Members
thank you spywolf !!
PowerArchiver 2007
Windows XP SP2
