Using NOD32 in PA?
I have NOD32 v3.0.699 and PA 11.02.03. What executable and command line settings do I use to have NOD32 scan files from the Actions menu?
Nothing? Perhaps I should explain, NOD32 is my virus scanner, it's quite common, I'd like to use it to scan files from within Powerarchiver.
you need to check NOD settings/help/instructions on what command line to use when scanning files... it is not PA specific.
Here's what I use:
Code:
Optional virus scanner: C:\Program Files\ESET\ESET NOD32 Antivirus\ecls.exe Parameters: --base-dir="C:\Program Files\ESET\ESET NOD32 Antivirus" --action=PROMPT If there's no problem, this will exit and close the command window before you can read it. If it finds a problem, it will prompt you on what to do... or it should; fortunately, I've not encountered this situation with PA and NOD32. |
thank you JackH!
We opened new thread for AV testing:
http://www.powerarchiver.com/forums/...ead.php?t=3463 If you are using some AV inside of PA, please post info inside that thread and we will update the OP. thanks everyone!
| Tags |
| command, executable, nod32, scan, virus |
