Old 10-13-2008, 07:30 AM
guido's Avatar
guido guido is offline
Alpha tester x
I guess it's Command Prompt
In the configuration it's called Command Line / Command Prompt.
See Image
Windows 7 x64 (NLD/ENG), I5-760
Old 10-13-2008, 11:22 AM
TBGBe's Avatar
TBGBe TBGBe is offline
Still Mainly Lurking
Maybe text with "prompt" would be too long for the menu?
Terry
WinXP SP3
Old 03-18-2009, 05:01 AM
guido's Avatar
Alpha tester x
still the same.
Old 04-15-2009, 09:58 AM
guido's Avatar
Alpha tester x
Not fixed in b3
Old 04-15-2009, 11:57 AM
ivan's Avatar
ivan ivan is offline
Alpha tester
thanks, will be fixed in updated b3.
PowerArchiver Support
http://www.powerarchiver.com
Old 04-17-2009, 08:12 AM
guido's Avatar
Alpha tester x
fixed
Closed Thread
