Old 08-15-2008, 02:39 PM
Luxor's Avatar
Luxor Luxor is offline
Alpha Tester
Slow display of files + high CPU
I think this may be similar to what I posted in this thread.
http://www.powerarchiver.com/forums/...ead.php?t=3275
But thought I had better start a new thread in case it's not.
The attached screen-shot probably explains it better.
If I click on the folder full of archives in the left explorer window, all my files appear instantly in the main window.
If I click on the + sign next to the folder or on the folder in the main window then there is a Over 30-40 seconds delay and CPU usage goes to about 50% before the files show.
There are about 30 pae files in the folder all around 90Mb in size, so you might need something similar to duplicate it, or maybe not.
Luxor
Vista home premium SP2. Always the latest Powerarchiver Toolbox
Old 08-25-2008, 04:26 PM
Please check Beta 5 via web update and see if this issue is still happening... Thanks!
Old 08-26-2008, 06:54 AM
Luxor's Avatar
Alpha Tester
Opening the folder in the main window files appear instantly.
Clicking on the + sign next to the folder in tree view and it disappears and no files appear below it.
Is that the expected behaviour now ?
Old 08-26-2008, 07:33 AM
are there any subfolders there? If not, thats how it should be... it should not show zip and cab files there anymore, that was the slow down, not only in explorer view, but also any add folder window in PA.
Old 08-26-2008, 11:43 AM
Luxor's Avatar
Alpha Tester
No sub-folders in there spywolf, so I guess it is working as intended.
So that's a fix then.
Closed Thread
