Old 08-07-2008, 09:48 AM
retnuh retnuh is offline
Senior Members
v5b2 - No error message, but no work done
I'm trying to eval PACL v5.00b2 with the following command:
pacomp -a -r -c1 -sep db.zip "d:\backups\DataBases\*.BAK"
It prints the standard header "PowerArchiver Command Line......" and then exits, no error, no files not found, nothing.
My end goal is to help automate my sql server backup zipping for offsite storage, so the addition of the "sep" param seems a really good fit.
I was able to run
pacomp -a test.zip *.exe
in the c:\pacl directory to validate it was working.
Old 08-07-2008, 11:05 AM
TBGBe's Avatar
TBGBe TBGBe is offline
Still Mainly Lurking
I believe -s requires that the password be input
so command should be
pacomp -a -r -c1 -sPassword -e -p db.zip "d:\backups\DataBases\*.BAK"
Your version could be trying to use 'ep' as the password or is that what you meant
Terry
WinXP SP3
Old 08-07-2008, 11:21 AM
Senior Members
nope
ah... nope I was trying to use the new param "sep" for create separate archives. Either way pacomp isn't reporting any kind of error to let me know something went wrong.
Old 08-07-2008, 05:51 PM
TBGBe's Avatar
Ah - Ok.
Tried
pacomp -a -r -sep \testing\ignore.zip "\testing\*.jpg"
Almost works for me (OK in the target folder: testing) I also get the file by file output listing.; so I cannot explain the no messages as you report.
But the subfolder recursion doesn't work
Note 1: which drive:folder are you running the command from - pacomp needs target info from the archive name; with your example would be in "current" folder.
Note: Cannot test with different drives, on this PC sorry.
Edit - just had a thought - if recursion is not working, then there may be no messages if your Backups\databases folder has NO .BAK files to compress.
Terry
WinXP SP3
