.Z file extracted as .txt
I'm using PACL v4.01, and like it so far. Simple to set up, simple to administer, and it runs well as a service account (without elevated permissions or registry access).
But when unzipping a .Z file, it throws a .txt on the end of the file name. Here are the details: - Original file: test.dat - Zipped file: test.dat.z - Command: paext -e test.dat.z - Unzipped file: test.dat.txt Why does it add the extra .txt extension? It doesn't do it for the same test.dat file zipped through WinZip. Thanks for any clarification / work around you can provide. Andy Wolfe |
.Z without .txt in 5.0
By the way, I just tested this in PACL5.0b. It extracts the file without adding the extra .txt extension.
So I guess that's the answer - upgrade to PACL5.0. Can anyone confirm that, or was this just a happenstance fix that might be re-introduced at some point? Thanks, Andy Wolfe |
Andy,
many changes were done to PACL to bring it to 5.00, basically all of the improvements from PA versions since PACL, should be included in 5.00 version.
