Go Back   PowerArchiver Forums > PowerArchiver 2012 > Wishlist
Old 03-12-2008, 10:57 AM
crunch crunch is offline
Senior Members
32bit Shell Extensions for Vista 64bit Needed
Creating wishlist topic per spwolf's request.
Reference: http://www.powerarchiver.com/forums/...3921#post13921
Old 03-18-2008, 11:20 AM
Senior Members
It's been almost a week, could I get a confirmation / eta for this please.
Thanks.
Old 03-18-2008, 04:30 PM
we never comment on wishes, until it is time to implement them or they were implemented...
future major release.
Old 07-26-2008, 08:39 AM
Senior Members
Please advise whether this will be fixed in PA 2009. Thank you.
Old 07-26-2008, 10:31 AM
we will implement the feature eventually, but i can not promise you when... and i could not find any threads on tc website on how to do it from original article, that might speed things up.
Old 08-21-2008, 05:55 PM
both threads you specify on original post, dont have any info except that it doesnt work...
I certainly could not find info on how to make it work or how other programs made it work? I might be blind and it is late here too...
Old 08-21-2008, 08:01 PM
mwb1100 mwb1100 is offline
Alpha tester
I don't run a 64-bit OS, so I'm not really sure if this will work, but if you can install both 32-bit and 64-bit PA side-by-side on the machine you should get both 32 and 64-bit shell extensions.
I do know this worked for an acquaintance that wanted 32 and 64-bit extensions for 7Zip.
Old 08-22-2008, 03:09 PM
Senior Members
http://www.mythicsoft.com/kb/Knowled...icle10020.aspx
I would try option 2, however the path should be dynamic and not hard-coded (needs to point to actual install path).
Old 08-22-2008, 07:13 PM
it really has nothing to do with what we need to do :-).
Is there an app that does it from install? So we can see how they are doing it.
But if I am thinking right, we would have to install two distinctivly different shell extensions which I am not sure that will work properly right now - in fact, i am sure it wont.
I will put it on the wishlist for 11.5...
Old 09-18-2008, 07:18 PM
Senior Members
Men, I'm seeing some truly fantastic features being implemented in PA 2009. And it kills me because these features are right up my alley and I'd be able to offer some really good feedback & suggestions, as I have in the past. But without 32-bit extensions working for 64-bit Vista the program is dead in the water for me. This situation is making me quite blue...
  #11
Old 09-18-2008, 07:27 PM
it is not simple - it will take a lot of our time, since way we access shell extensions right now would have to be changed due to 2 extensions installed at the same time.... so thats why no way we could have done it for 11.00...
  #12
Old 09-18-2008, 07:41 PM
Senior Members
Okay..
  #13
Old 09-18-2008, 07:55 PM
Senior Members
Is there any way the method for choosing which extension is installed/used can be user-configurable? At the moment I believe the installer is making a default decision based upon which version of OS is detected (since there aren't separate downloads for 32-bit / 64-bit).
This would at least offer a choice for people that need PA to work with 32-bit apps running on 64-bit Windows and wouldn't require changing the system for accessing shell extensions to allow 2 concurrent shell extensions, one for each architecture..
Another idea is splitting up the versions, one for 32-bit and one for 64-bit. True, having one installer for both versions is cooler...but this isn't working 100% yet. If there were separate installers it might be possible to install them to separate directories and 'hack' compatibility for both architectures temporarily, no?
It doesn't have to be pretty for now - we understand it will take fundamental changes for it to be done the right way - but please at least offer a temporary workaround. This is a blocking situation (there, I didn't call it a bug ).
  #14
Old 08-20-2009, 02:38 PM
Alpha tester
I'm finding that I need this support too (running 64-bit XP Pro and wanting to use a 3rd party filemanager that's 32-bit only).
I'm near certain that if you made a 32-bit-only installer available that I could get this to work well enough by having 32 and 64 bit PAs installed side-by-side. This workaround works for other shell extenders (TortoiseSVN for example).
  #15
Old 09-08-2009, 10:45 AM
Its party time
