Old 01-31-2008, 07:33 AM
craniac craniac is offline
Junior User
Excluding file only in root folder
Using pacomp I am trying to zip up a folder tree that contains a web.config file in the root folder as well as in sub-folders.
I wish to exclude the one in the root directory but include the ones in sub-folders. Is this possible?
If I use -xweb.config or -x"\web.config" then all web.config files are excluded and if I use -x".\web.config" then none of the web.config files are excluded.
The rest of the command I'm using (with the questionable exclusion represented by ???) is
Code:
pacomp -a -r -p ??? -x"bin\*.config" FMWeb.zip FMWeb\*.*
The other exclusion command works correctly to exclude other .config files from the bin sub-folder.
Old 02-01-2008, 05:45 AM
TBGBe's Avatar
TBGBe TBGBe is offline
Still Mainly Lurking
Two possibilities I can think of off the top of my head (not tried) -
1. include the root folder name
-x"FMWEB\web.config"
2. create and use a @list of all the files to be excluded.
Terry
WinXP SP3
