Compression ratio
I am trying this software for the first time to compress a 130Gb IBM DB2 Backup of a database. I used the default compression ratio and ended up with a file that is under 600Mb.
Is this even possible? Its gonna be hours, if not a full day b4 i can uncompressed and test it. Any info would be nice. Thanks |
Sorry, but currently PACL compression (any type) does not support such a large amount of data - the current limit is ~2GB
![]() If you don't need command line - try PowerArchiver for Windows.
Terry WinXP SP3 |
